Adapt 25fps in 50 with "alpha" frames
COW Forums : VEGAS Pro
Alain Azpeitia
on May 3, 2017 at 11:35:03 pm
I want to put a 25fps video in a 50fps edit but the frames repeat like this to get 50 fps full of images:
1-1-2-2-3-3....24-24-25-25
I want to create blank empty and transparent frames betweem them, so if i add a video in a layer below it I could see it.
1-transparent-2-transparent...24-transparent-25
How can I do that?
Thanks.
László Kovács
Re: Adapt 25fps in 50 with "alpha" frames
on May 4, 2017 at 6:14:29 pm
I know I'm repeating myself, but my only idea is to take Vegasaur in such a case.
You can achieve what you want using Vegasaurs "strobe light effect".
Set Duration, pause duration to exactly 1 frame, fade duration to zero.
That creates a composite level envelope for you on the selected track over the selected time range.
Best regards
László Kovács
Alain Azpeitia
on May 6, 2017 at 10:18:46 am
Thank you very much! It worked like a charm! :)
