Renders jitter or show same clip over and over...
COW Forums : VEGAS Pro
Tim Kretschmann
on Apr 27, 2017 at 12:51:47 am
So, I never had problems rendering. I had source video, though, lower resolution. All of a sudden, I can't put bottom thirds on there or do transitions without it going...crunch. The preview screen goes first during the edit and then during the render I get the same 5 seconds of video as the audio prattles on or the video just stutters.
I want the higher res for editing because I zoom in plenty, but if it is going to do this....I'm going to have to do a plan B. Any troubleshooting hints?
Henk Petersen
Re: Renders jitter or show same clip over and over...
on Apr 27, 2017 at 11:32:47 am
When I have phenomena like that, it is always due to the GPU being used but not functioning in harmony with the CPU as it should. You can check that quickly by prohibiting the use of the GPU in Options\Preferences\Video. It gets worse as you add effects, transitions etc.
Steve Rhoden
on Apr 30, 2017 at 7:16:45 pm
A solution that might work, is that whenever you are ready to do your final renders,
simply restart Vegas, load back your project and then start your rendering!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Tim Kretschmann
on May 1, 2017 at 8:06:08 pm
I'll give that a shot.
Steve Rhoden
on May 20, 2017 at 9:13:00 pm
