How to get this to 50 meg or less (and still able to view captions well)
COW Forums : VEGAS Pro
Amanda Duffield
on Apr 26, 2017 at 7:02:46 am
Hello all,
I have a 10 min excerpt from a TV show - details are below. I need to compress down to 50mg or less to fit on our shared area (yes, copyright is sorted with users having to click through various acknowledgments). It does have captions (burned in from broadcast) so needs to stay clear enough for them to be readable, but other than that, no real stipulations other than size.
I have SVP13 and Handbrake.
Thank you very much ☺
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 405 MiB
Duration : 4mn 25s
Overall bit rate mode : Variable
Overall bit rate : 12.8 Mbps
Encoded date : UTC 2017-03-02 09:58:25
Tagged date : UTC 2017-03-02 09:58:25
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=4, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4mn 25s
Bit rate mode : Variable
Bit rate : 12.6 Mbps
Maximum bit rate : 24.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.243
Stream size : 398 MiB (98%)
Language : English
Color range : Limited
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 4mn 25s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : channel0
Channel(s)_Original : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 6.08 MiB (2%)
Language : English
Steve Rhoden
Re: How to get this to 50 meg or less (and still able to view captions well)
on Apr 26, 2017 at 10:19:28 pm
Try using the Vegas to Handbrake Script and render out as mp4 through Handbrake:
Excellent results with very small file size output...
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Amanda Duffield
on Apr 27, 2017 at 11:12:39 am
Thank you so much. Sorry to sound obtuse but i don't know skewewhere to get that? Do i download it?
Thanks again
Wayne Waag
on Apr 27, 2017 at 10:07:13 pm
You're probably too late since the author has removed it from his website. it used to be here.
http://www.vegasvideo.de/vegas-2-handbrake-en
wwaag
Marco Baer
on Apr 28, 2017 at 12:54:32 pm
Actually I didn't remove that certain page but my whole VegasVideo.de website is down since end of 2016 due to some server modifications which are not compatible with the CMS version I used for creating the site.
You could still access the page via a web archive:
https://web.archive.org/web/20161013201440/www.vegasvideo.de/vegas-2-handbr...
But you should know that the description and the linked files doesn't take care of the changes made to the scripting language since Magix took over, also it is not modified for the use of the current HandBrake version. What you'll find on the web page is meant for the use of the Sony branded versions of Vegas Pro 11 to 13 and HandBrake before version 1.0.
I had to stop updating Vegas2HandBrake because meanwhile there are too many variations of Vegas Pro and other tools involved with each would need own modifications. I once made this workflow for my own use only and my limited time does not allow anymore to trace each of the tools involved, doing the modifications needed and updating files and descriptions, sorry.
Graham Bernard
on Apr 28, 2017 at 1:25:27 pm
Thanks Marco.
* Grazie
Steve Rhoden
on Apr 28, 2017 at 9:30:35 pm
Great, you provided the link Marco....
