How to make Mercalli stabilization permanent on a clip?
COW Forums : VEGAS Pro
Scott Francis
on Apr 25, 2017 at 8:40:06 pm
Hey All,
I have been told it a good idea to "bake in" Mercalli after one stabilizes a clip. Anyone know how to do this or can share a link to something that can help?
Thanks a bunch!
Xavier (Scott) Francis
Mind's Eye Audio/Video Productions
Paul Berk
Re: How to make Mercalli stabilization permanent on a clip?
on Apr 25, 2017 at 9:57:39 pm
Only way to "bake" in the Mercali is to render the event and use the rendered file in your timeline. I generally use something lossless like a SONY MXF file.
Wayne Waag
on Apr 26, 2017 at 3:24:40 am
Lots of ways to do this. Inside of Vegas, the easiest to simply use "Render to New Track" (Ctrl-M). First establish your loop region and then select that option in the dialog. Use whatever codec you like. Lossless is best, but something like XAVC-S also works well.
wwaag
Graham Bernard
on Apr 26, 2017 at 5:03:45 am
[Wayne Waag] "the easiest to simply use "Render to New Track" (Ctrl-M)"
Been using this for ever. And then I add the render back to the Event as a New Take and then, keeping things tidy, delete the Render to New Track track. It's a bit of a roundtrip, but it works.
* Grazie
Scott Francis
on Apr 26, 2017 at 9:06:00 pm
That's a big help!!!
Thanks so much!
Peter Roehrer
on Apr 28, 2017 at 12:35:19 pm
Dear all,
I think I have nearly the same problem.
I just bought "Magix Vegas 14 Suite" because of "Mercalli V4.0".
But now I have great problems with Mercalli.
Sometimes it forgets that the clip was just analysed.
There are some lonely messages like a frame containing the message that the clip must be reanalysed. Very bad.
In some Forums I found that some people had the same problem. The only solution seems to be not to use Mercalli.
The workaround to render to a new track is good but it generates a huge amount of work. My project contains many clips which should be stabilized with Mercalli.
The best would be a script, which analyses every Clip if it contains "Mercalli V4", then render this Clip to a new track with a filename close to the origin clip adding an extension and then replace the original clip.
I did not find a tool which does this. If there is a tool to do this I would buy it.
I would write a script but I am not the best programmer on earth.
Anybody an idea?
Thanks.
Graham Bernard
on Apr 28, 2017 at 4:30:08 pm
[Peter Roehrer] "Sometimes it forgets that the clip was just analysed."
This will happen if you do anything to change the Event.
If you have many wobbly clips then use the Standalone version. Is that included with your package?
* Grazie
