S key
COW Forums : VEGAS Pro
Jack Gill
S key
on Apr 16, 2017 at 8:49:33 pm
My S key (split) is erratic. Sometimes it works fine and then stops working. I have to close down and open back up to get it working again. Frustating.
George Dean
Re: S key
on Apr 17, 2017 at 12:58:43 am
Hi Jack,
You may want to do a program reset. From the desktop, hold down Shift+Ctrl keys and double left click on the program icon. Before clicking 'Yes', be sure to check 'Delete all cached application data.' That will set your program back to installation defaults and delete any application data which may have built up and may have gotten the program confused after while.
Best Regards.....George
Graham Bernard
Re: S key
on Apr 17, 2017 at 3:17:07 am
[Jack Gill] "My S key (split) is erratic. "
Are you absolutely sure you have clicked on the Event/s or have Selected the Events needing to Split? Also, have you got Quantize to Frames enabled?
* Grazie
