Using Velocity Envelope, Loosing luminosity
COW Forums : VEGAS Pro
Francois Pénzes
on Apr 9, 2017 at 3:36:00 pm
Hello everyone
First time using this feature in Vegas and I am completely at a loss... I am applying the Velocity Envelope to a 45 sec. clip with a white background in increments of 250% each time after render. (I have to narrow it down to 6-7 seconds)
Each time I apply the envelope, I lose about 7% luminosity. Red channel stays the same, green drops a bit and blue even more.
Project is an Sony .MXF file, 50Mbps (CBR), 59.940 fps prog.
I can't figure it out.
Any suggestions ? Explanation ?
Cheers !
PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
''When the cutting stops, the editing begins...''
Paul Berk
Re: Using Velocity Envelope, Loosing luminosity
on Apr 10, 2017 at 2:22:11 am
First, which version of Vegas are you using?
Second, are you talking about "velocity"or "composite level"? Why would Velocity (speed) reduce your luminosity?
Francois Pénzes
on Apr 11, 2017 at 12:37:39 am
Hi Paul
I'm using V.14 and Velocity only.
That's the thing, it shouldn't affect the luminosity as far as I understand it. There are no other effects applied, not even Event Pan/Crop. All files were shot with the same camera, same controlled lighting, on the same morning, inside.
I'm at a loss...
Cheers !
Paul Berk
on Apr 11, 2017 at 5:05:17 am
Three questions.
Are you measuring the loss of luminosity after the render in the rendered file?
How exactly are you measuring the luminosity at about a 7% drop each time?
Can you repeat this behavior with different media and different render settings?
Francois Pénzes
on Apr 11, 2017 at 10:23:31 am
Hi Paul
[Paul Berk] "Are you measuring the loss of luminosity after the render in the rendered file?"
Yes, after I import it back to Vegas
[Paul Berk] "How exactly are you measuring the luminosity at about a 7% drop each time?"
With the Vegas included Waveform (luminance)
[Paul Berk] "Can you repeat this behavior with different media and different render settings?"
I will do some testing and get back to you.
Many thanks for your time !
Cheers !
Francois Pénzes
on Apr 13, 2017 at 12:52:51 am
Hi Paul
Tried it with other rendering formats and could not reproduce the problem. I was hoping to keep all my files in the same format as the original files.
If you ever come up with even something of an explanation, let me know.
Cheers ! ...and thank you !
