Vegas plugin not loading properly
COW Forums : VEGAS Pro
Jack White
on Mar 27, 2017 at 8:01:57 pm
Plugins like colour gradient are not loading properly, in Vegas 13 &14 , tried resetting my laptop, and updating graphic card drivers. Problem still persists.
Using a Lenovo laptop
Laptop is i7, Nvidia 960m with windows 10
Screenshot : https://ibb.co/dD9pVa
Graham Bernard
Re: Vegas plugin not loading properly
on Mar 27, 2017 at 9:02:36 pm
Yeah, this has been reported before now. What is the Build number? Tried to reboot? GPU off or on? I've had this at times with VP12 in earlier builds.
* Grazie
Paul Berk
on Mar 27, 2017 at 9:07:50 pm
SEE IF THIS HELPS
Graham Bernard
on Mar 27, 2017 at 9:10:32 pm
Yeah, nasty.
* Grazie
Jack White
on Mar 27, 2017 at 9:44:09 pm
Nope, didn't help, tried all of that except for the registry edit, as that particular registy ms sans serif etc, doesn't exist
Jack White
on Mar 27, 2017 at 9:08:52 pm
Version 13 build 453
Tried, rebooting no change.
Tried putting DPI scaling off, from the properties of the icon , no change
Tried changing the rendering from integrated GPU to dedicated GPU no change.
Tried even resetting the windows deleting all apps just keeping the personal files , no change.
Not sure what to do next.
Graham Bernard
on Mar 27, 2017 at 9:11:24 pm
Reinstall VP13?
* Grazie
Jack White
on Mar 27, 2017 at 9:25:49 pm
Yup, done that.
That was the first thing I did after resetting the pc, incase any applications were interferening . It would be interesting to note that I installed the same software on my friends Dell laptop, with a 940 Nvidia you and it worked. Not sure what's the holdup in mine
Graham Bernard
on Mar 28, 2017 at 3:42:49 am
Would you try uninstalling and reinstalling? Firstly reboot, uninstall, reboot and reinstall.
* Grazie
Jack White
on Mar 28, 2017 at 7:08:00 am
Yup, did just that right now, did not work same problem
Graham Bernard
on Mar 28, 2017 at 8:00:43 am
Well, I'm full out of ideas. Other than a drastic deletion of all things VP, including your plugins, and if that's not happening, then a Restore from a working restore point.
Sorry, but this is a flaky error that's hit me as well as others. My cure was NOT to use the FX and wait for a new, then, SONY build. Oh, did anybody suggest a reinstall of your video drivers? Had you done prior to this error?
* Grazie
Jack White
on Mar 28, 2017 at 10:20:46 am
Yup, tried all all those things including resetting the entire pc and updating the drivers to no avail. Guess I'll have to stop using VP
Graham Bernard
on Mar 28, 2017 at 10:24:49 am
[Jack White] "Guess I'll have to stop using VP"
'Cos of one FX? Yup, I'm guessing you will have to.
* Grazie
Jack White
on Mar 28, 2017 at 10:34:53 am
It's not just one FX, it's almost all of the fxs that fall under the title "colour gradient"
Graham Bernard
on Mar 28, 2017 at 11:25:39 am
[Jack White] "It's not just one FX, it's almost all of the fxs that fall under the title "colour gradient""
This is a Generated Media. In your first post you state that it s with VP13 Build 453. However your ScreenGrab is from VP14. What build of VP14 are you trying?
Here's mine:
* Grazie
Graham Bernard
on Mar 28, 2017 at 11:35:32 am
Jack, try this. Not saying it WILL work, but, try changing your Columnar View to 2 Columns - click on the one next door:
* Grazie
Jack White
on Mar 28, 2017 at 11:50:56 am
Tried that, didn't work actually, the changing buttons of 1 column to 2 columns are solid, and doesn't get pressed but I managed to change by going to another FX and coming back, but no use.
Just tried most of the fxs.
The problem extends to
Color gradient
Credit roll
Test pattern
(Legacy) text
VP 14 build 161
VP 13 build 453
Tried on both
Graham Bernard
on Mar 28, 2017 at 12:00:48 pm
[Jack White] "VP 14 build 161"
Latest Build here is 211. Did you download that? But before you do this try deleting VP completely off of your system - AT YOUR RISK! - prior to rebooting and then installing Build 211.
I'm trying here! - You DO see that mine is working.
* Grazie
Jack White
on Mar 28, 2017 at 1:05:54 pm
Tried that, deleted VP completely and re installed the latest (211) . Still the same.
And I really do appreciate all your help.
Jack White
on May 7, 2017 at 4:07:19 pm
Hey,...
So update : finally got it to work, updated to windows 10 creators update, and launched Vegas again. And voila... The problem has been solved.
Once again gonna thank thee for your help.
