Script to restore deleted audio to video event -- vegas pro 13
COW Forums : VEGAS Pro
lars hansen
on Mar 22, 2017 at 8:08:03 pm
Looking at a few old forums there appears to be a script called "RecreateAudioEvents.js" that restores deleted audio associated with a video event.
Does anyone know where I might get a copy of such a script and if it works in SVP 13?
https://vimeo.com/longdcycler
László Kovács
Re: Script to restore deleted audio to video event -- vegas pro 13
on Mar 22, 2017 at 8:37:49 pm
I know for sure Vegasaur has this functionality.
So if you don't find that script, it may worth to give Vegasaur a try.
Best regards
László Kovács
Paul Berk
on Mar 23, 2017 at 4:36:05 am
László .. that script in Vegasaur must be for the original camera audio for a particular video clip .. easy enough to find and match to a video event but I can't see this working for 'wild sound" .. I think the OP is talking about sound from his H6 Zoom, not the camera.
Graham Bernard
on Mar 23, 2017 at 5:33:35 am
I use the Mighty Excalibur by Edward Troxel. The A/V restore Icon sits loud and proud on my Toolbar.
OK, just went down Memory Lane with some Google searching. I found the script on the Calderwood site. I haven't used the script nor can I vouch for it in any way!:
* (re)create audio parts on seperate audio track for all selected video events
import System.Windows.Forms;
import Sony.Vegas;
try {
// create new target audio track
var targetTrack = new AudioTrack(-1,"Missing Audio");
Vegas.Project.Tracks.Add(targetTrack);
// step through all selected video events:
for (var track in Vegas.Project.Tracks) {
for (var evnt in track.Events) {
if (!evnt.Selected || evnt.MediaType != MediaType.Video) continue;
// create a fitting audio event and add to target audio track:
var audioEvent = new AudioEvent(evnt.Start,evnt.Length);
targetTrack.Events.Add(audioEvent);
// step through all events of selected video event
for (var tke in evnt.Takes)
// find first audio stream in this takes media
var aviFile = new Media(tke.MediaPath);
for (var stream in aviFile.Streams)
if (stream.MediaType != MediaType.Audio) continue;
// create new take out of this audio stream
var newTake = new Take(stream,tke.IsActive);
// add it to target audio event (must be done before anything else!!)
audioEvent.Takes.Add(newTake);
// fit offset to video event
newTake.Offset = tke.Offset;
break; // we assume there's only one audio part in any avi file
audioEvent.Selected = true;
} catch (e) {MessageBox.Show(e);}
This needs to be reworked for the new owners of VP. Here's that Calderwood site: http://s92274348.onlinehome.us/vegas.html
* Grazie
lars hansen
SOLVED: Script to restore deleted audio to video event -- vegas pro 13
on Mar 25, 2017 at 7:13:33 pm
Thankyou kindly Grazie! This appears to be the ticket!
I've downloaded the collection of scripts via the site you referenced and what a list! I assume that some of these are outdated/redundant now?... That said, there are quite a few scripts there I have moved into my Vegas script folder as they’re great short cuts to completing more time consuming tasks (e.g “Normalize”, which normalizes audio for an entire track!).
I have tested the "Recreate Audio Events" from the collection (which is the script I assume you pasted above) and it appears do exactly what I want.
For those who want to learn a little more about installing and using scripts here's a good video by Scott Eggleston:
Cheers! LDC
