vegas pro 13 how to restore deleted audio to video event
COW Forums : VEGAS Pro
lars hansen
on Mar 20, 2017 at 6:30:41 pm
Hi folks,
I'm wondering if there is a (simple) way to restore deleted audio to an event on the timeline. I'm doing a multicam edit so finding the exact audio off of one of many long takes is going to be a pain to say the least. Preferably solution would be something I can do with vegas "out of the box", but I'm open to other solutions too.
Ideas?...
https://vimeo.com/longdcycler
Paul Berk
Re: vegas pro 13 how to restore deleted audio to video event
on Mar 20, 2017 at 7:40:25 pm
Is this "wild" audio you deleted, or was it an audio track from the camera taken along with the video?
lars hansen
on Mar 20, 2017 at 8:12:22 pm
It was audio taken with the camera (GH4). I have seperate H6 audio that I need to sync the video to.
The latter step will be easy, recovering the camera clip/event audio is the challenge -- I'm surprised this feature was not comonplace with SVP?
Paul Berk
on Mar 20, 2017 at 8:34:38 pm
Do you have the video that matches up to the "deleted" audio? If so, why can't you locate the spot by the video?
Can you open the video that corresponds to the "deleted" audio in the trimmer?
lars hansen
Script to restore deleted audio to video event -- vegas pro 13
on Mar 22, 2017 at 8:03:34 pm
Looking at a few old forums there appears to be a script called "RecreateAudioEvents.js".
Does anyone know where I might get a copy and if it works in SVP 13?
lars hansen
Re: Script to restore deleted audio to video event -- vegas pro 13
on Mar 22, 2017 at 8:46:54 pm
Hi Paul, thx for the suggestion.
While I could do this, I started this project as a four camera multicam shoot. It's a half hr long and I have three tracks of separate “master” (H6 recorded) audio. As the project has evolved this combination has resulted in a highly "sliced and diced" timeline (both video and master audio tracks).
Unfortunately the video became ungrouped (I believe that's what SVP does when you move in and out of the multi cam edit mode/feature) and eventually desynced from the master audio tracks as the edit progressed. The easiest fix now seems to be to bring back the corresponding camera/video event audio and run pluraleyes. I’m hoping to find an easy way to do this...
I'm quite amazed that this feature does not exist within SVP as a standard feature; perhaps something Magix might consider in the future version of Vegas?...
lars hansen
SOLVED -- Script to restore deleted audio to video event -- vegas pro 13
on Mar 25, 2017 at 7:16:49 pm
Thanks to Grazie, I have found the solution to my problem!... . See this Cow thread for explanation... https://forums.creativecow.net/thread/24/1017125
Graham Bernard
Re: SOLVED -- Script to restore deleted audio to video event -- vegas pro 13
on Mar 25, 2017 at 7:50:48 pm
U R Welcome!
* Grazie
