Sony Vegas Pro 12 64 bit Win 10
COW Forums : VEGAS Pro
Kevin Byrne
on Mar 20, 2017 at 3:32:20 pm
Hello,
I had to uninstall SVP12 770 and reinstall from my disk SVP12 version 367.
Having even more trouble with this than the version 770 I had to uninstall, but at least it does not crash when attempting to open a file from the menu.
I have searched high and low for a 770 patch but only get installs for SVP 14 Anyone know where I can get a clean SVP 12 64 BIT 770 Patch / update
Any help appreciated.
Kevin Byrne
Mike Kujbida
Re: Sony Vegas Pro 12 64 bit Win 10
on Mar 20, 2017 at 3:37:50 pm
Scroll down to 4a on this thread for a direct link.
There are other options too.
https://www.vegascreativesoftware.info/us/forum/faq-where-can-i-download-ve...
Kevin Byrne
on Mar 20, 2017 at 3:51:18 pm
Hi Mike,
Thanks very much, much appreciated, I was on that page at sometime in my travels but must have done something wrong.
Yours faithfully,
Kevin.
Mike Kujbida
on Mar 20, 2017 at 4:02:11 pm
You're very welcome Kevin. Glad I could help.
Kevin Byrne
on Mar 20, 2017 at 4:18:47 pm
Mike ,
More problems.
My initial problem was SVP12 770 Opening then the Magix pop up appears asking me to upgrade to SVP 14, I would go to file in UI to select and place a video file (type not relevant) as soon as I clicked same Vegas pop up error box appears (see attachment) saying it has to close and report what I was doing.
I have deleted Vegas app cache, and it fixed the problem I shut down pc went to bed went to use it again Monday night and have the same problem.
I uninstalled from my HD Re installed from my disk and just updated thanks to you and your link to 770 patch
I am now back where I started with same problem again. Is Magix trying to force SVP 12 users to update to 14 by disabling 12?
Have you heard of my problem before or do you have any ideas as to what might be causing it ?
Thanks for your time,
Kevin.
Mike Kujbida
on Mar 20, 2017 at 6:03:25 pm
Kevin, I use Pro 12 on Windows 10 also and haven't experienced your problems.
Here's an FAQ that hopefully will help you in finding your problem. Good luck.
https://www.vegascreativesoftware.info/us/forum/faq-troubleshooting-crashin...
Kevin Byrne
on Mar 20, 2017 at 6:31:57 pm
Hi Mike,
Thanks again.I think I have it related to one particular file containing TS files.
If I stay away from that one it is now working fine.
Will check out the link you sent me.
Thanks ,
Kevin.
