DV 720x576 render to blu ray?
COW Forums : VEGAS Pro
Odd Egil Overskeid
on Mar 18, 2017 at 6:08:27 pm
Hello,
I have captured DV 720x576 25FPS PAL to AVI files. I made a project in Vegas.
I have a blu ray burner and 50GB discs.
Which resolution should i render to ? i know i can just hit 1920 but i guess there is a limitation of quality in the DV in which i will just end up with large files and not better quality.
Regards
Oddemann
Eric Clinch
Re: DV 720x576 render to blu ray?
on Mar 18, 2017 at 11:16:36 pm
I'd render to 720x576 mpg. DVDA should take them without recompression and your Blu-ray player will upscale them when it plays them. Most players I've encountered do a good job when upscaling.
If you want to put them on the disc as 1080 then rather than just export try upscaling fx. There's one in the Boris suite if you have it. I haven't tried it.
