Black screen in some scenes
COW Forums : VEGAS Pro
Vidoje Isakovic
on Mar 10, 2017 at 4:14:52 pm
Hello all.
I put in my video "S_dissolveShake" effects,this effect i used to transitions,otherwise that is COD MW 2 Montage..
when rendering video, this effect did not work,just appeared black screen,I tried change video settings to "Disable Resample" but it did not work
at the end of each scene, I put transition DissolveShake effect,you can see on this picture
at the beginning of the video effect is worked,but from some moment,transition and Video Fx did not work and showed the black screen instead effect
i using Sony vegas pro 11 (32 bit)
This is my render settings
© 2018 All Rights Reserved
