Track Motion Keyframe added even when Sync cursor unchecked
COW Forums : VEGAS Pro
Mel McMurrin
on Mar 9, 2017 at 7:05:17 pm
For many years I've lived with what I've assumed is a bug.
I use Vegas a good chunk of the time for quick motion graphics. I am constantly turning track motion sync cursor on and off: ON to create a new keyframe where time-line Cursor is, then OFF to make changes to that new keyframe (after moving Timeline cursor forward a touch so I can see changes in the video preview.) More often than not track motion creates a new keyframe at the new time line cursor position even though sync cursor is off. Closing/Opening track motion can often fix...but not always. When the keyframes number in the hundreds its a real drag!
I believe I've seen this behavior versions 6-13. If 14 fixes this I might just have to upgrade.
(and if it fixes a second annoyance where track motion undo sets the cursor back to 0:00:00 I'm definitely there!)
Anyone know what I'm talking about?
László Kovács
Re: Track Motion Keyframe added even when Sync cursor unchecked
on Mar 9, 2017 at 9:04:25 pm
If you have sync cursor off, main timeline cursor may be anywhere, while (keyframe) cursor stays at another position.
If you make a movement at this position (track motion, parent motion), even a fraction of a pixel, a keyframe is automatically created with the new values.
This is how Vegas 14 (and Vegas 10 I used before) behaves in this regard, and I really think this is the normal behavior.
What you describe:
[Mel McMurrin] "More often than not track motion creates a new keyframe at the new time line cursor position even though sync cursor is off."
I never noticed such a behavior, and I often use trackmotion and pancrop keyframed as well.
Best regards
László Kovács
Mel McMurrin
on Mar 9, 2017 at 10:33:05 pm
Thank you László!
Your description clarified it for me. I had assumed that a highlighted keyframe should mean that I am editing that keyframe! Silly me. So in addition to setting sync cursor off I need to move the track motion cursor back to the keyframe I wish to edit. Ah my poor mouse hand, lots of moving between timeline and track motion window...but you are right I think this is normal behavior.
I bet going back to 0:00:00 after a track motion undo is "normal" too ... I can't tell you how many time's I've been making track motion changes to the first keyframe not the 100th one as I thought! The fix: delete keyframes and start over don't Cntrl-Z them (or never make key frame mistakes!)
Paul Berk
on Mar 9, 2017 at 10:45:55 pm
I agree with Laszlo .. there is no way to turn off automatic keyframing. When you change your track motion setting, a new keyframe is created, unless there already is a keyframe at that exact position.
>> in the video preview. More often than not track motion creates a new keyframe at the new time line cursor position
I'd say you should leave the "sync cursor" on all the time.
Why do you need to move the timeline cursor forward to see preview? If you just leave the cursor where you just created a new keyframe, you should be able to adjust Track Motion and see it in the preview without creating another keyframe. The trick is to STAY exactly on the newly created Keyframe.
Preview is controlled by the Timeline cursor, not the Track Motion Timeline cursor, but if "sync cursor" is ON, you should be ok as they would be at the same position. Unless I'm misunderstanding you.
Mel McMurrin
on Mar 9, 2017 at 11:43:38 pm
Thanks for chiming in Paul,
My experience is that timeline cursor must be forward of the keyframe or you will not see the actual position in Preview.
Notice how in picture 2 position of red box in Preview maintains position of previous keyframe (picture 1) until moving forward (picture 3)
This is always the way it has worked for me...if yo have a setting which will change that I will be very grateful!
Paul Berk
on Mar 10, 2017 at 12:02:00 am
Thanks for taking the time to explain with the screen grabs.
I can't duplicate that behavior. Maybe I don't get it ?? .. When I create the second keyframe, I see it in preview exactly -- no need to move the timeline forward to see the placement -- and as long as I stay on that keyframe, I can adjust all I want without creating an unwanted keyframe. I think this is normal behavior. What your seeing, to me, is not the way things should work.
Something might be up here with your system -- or like I said -- I may not be getting it.
With sync cursor on, can you go back with the Track Motion cursor to one of the already created keyframes and do track motion adjustments, seeing those adjustments in preview as you do them?
Paul Berk
on Mar 10, 2017 at 12:12:25 am
I just tried this is VP13 .. I see the problem now -- just as you described.
I think it has to do with HOLD. The work around is to place all your keyframes first as LINEAR and then go back and make them all HOLD or the ones you need for the effect.
VP14 seems not to have the problem at all.
Mel McMurrin
on Mar 10, 2017 at 3:17:56 am
Hey thanks Paul for verifying I'm not crazy!
Yes, I almost always work first with HOLDs for precision then change them to LINEARS etc for smoothness as needed. That is great news about VP14. I have a vague memory that VP 6 behaved "correctly", and was just about to install it to see.
Now tell me this, with the track motion sync cursor off, make a change to a keyframe (HOLD or LINEAR) and then undo....does track motion cursor move back to 0:00:00? in VP14? In VP13?
Paul Berk
on Mar 10, 2017 at 3:46:30 am
Yes. Same behavior in VP14 .. undo bounces you back to the head of the Track motion timeline, 00:00:00. Bummer.
Paul Berk
on Mar 10, 2017 at 3:48:40 am
But .. with Sync cursor ON .. undo works as you'd expect. Stays put.
I generally work with Sync cursor ON so I never noticed this behavior.
Mel McMurrin
on Mar 10, 2017 at 8:46:33 pm
Thanks for the research Paul.
I've tried over the years to work with sync ON, but I end up with unwanted Keyframes dropped all over the place!
