Question about video properties for different fps clips
COW Forums : VEGAS Pro
Herman Yn
on Mar 8, 2017 at 1:07:11 am
Hello, I have a question. I use AMD Relive to record gameplay footage but right now the video recorder has a bug where it records at framerates slightly lower than what it's supposed to. I have it set to 60 fps, but some clips are at 57 fps, 58 fps, and 59 fps.
I am combining these clips together in a video and am going to render it at 30 fps (since the framerate in-game is kind of inconsistent anyway). Should I set the project properties setting to 57 fps or 59 fps? Does it matter? Will a lower or higher project properties fps affect any of the clips in a negative way after they are rendered?
Thanks.
