How do you make one part of a video come out before/after the rest of it?
COW Forums : VEGAS Pro
Fabio Giugliano
on Mar 4, 2017 at 3:14:45 pm
I think I explain it better here:
Francois Pénzes
Re: How do you make one part of a video come out before/after the rest of it?
on Mar 5, 2017 at 3:29:44 am
Hi Fabio
Move the track with the controller ahead by 1 frame and that should do the trick. If all your other points are in sync, then just ''CTL-S'' to split you track and replace frames accordingly.
Cheers !
PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
''When the cutting stops, the editing begins...''
Francois Pénzes
on Mar 5, 2017 at 11:14:13 am
Hi again Fabio
I made a mistake, it's not ''CTL=S'' but ''S'' only to split the timeline.. 2 pots of coffee and 14 hours of editing will do that to you.
Sorry again mate,
Cheers !
Fabio Giugliano
on Mar 5, 2017 at 1:05:46 pm
Hello Francois.
There's not a track of the controller and a track of the video. I recorded the video with controller + gameplay. It's just one video :/
Francois Pénzes
on Mar 5, 2017 at 4:07:48 pm
Hi Fabio
I was under the assumption that you had 2 distinct video tracks.
Here is what I think is the easiest way out for you short of re-recording.
1- Duplicate your video track, one on top of the other.
2- Split your top track in order to separate the 2 tracks.
See attached pick for what I have used. There are other ways to do this but this should work for you.
Cheers !
Fabio Giugliano
on Mar 6, 2017 at 2:30:32 pm
Ah, I see now. It works, thanks a lot! =)
