Vegas Pro 14 - Sound edit problem.
COW Forums : VEGAS Pro
Bob Wachtman
on Feb 22, 2017 at 9:48:08 pm
Newbie to Vegas Pro 14.
Have an AVCHD file with audio on left track only. What is the easiest way to copy left to right for a mono result? If I try to open the audio file (or a copy of it) in SoundForge, I get an error... "file is an unsupported format". Seems like this should be a simple edit, but I can't figure it out.
Graham Bernard
Re: Vegas Pro 14 - Sound edit problem.
on Feb 22, 2017 at 9:56:56 pm
Right click on Audio Event and select Channels. From there you can do everything.
* Grazie
Bob Wachtman
on Feb 22, 2017 at 10:26:15 pm
Thanks, Grazie. Appreciate your fast comeback. Where do I find "Audio Event" to right click on?
Bob Wachtman
on Feb 22, 2017 at 10:46:54 pm
OK... I found "Channels" on the Edit pull-down and selected "combine". That did it! Thanks again... your reference to "channels" gave me the clue I needed... couldn't have done it otherwise.
