Vegas 14 render issues, problems, crash, Vegas 13 fine
COW Forums : VEGAS Pro
MIke Francis
on Jan 30, 2017 at 9:54:48 pm
I have upgraded to Vegas 14 build 211. I do long meetings and Vegas 14 is crashing all the time during render unless the project is under 1/2 hr....... Vegas 13 on the same computer is fine. So if you want to upgrade you may want to wait to see if they fix it. I have found support to bad. I have sent Magix screen shots of error messages with no one letting me know what is happening if they are fixing or because most people do not do projects that long they don't care. Beware you have been warned once you save your veg file as 14 you can not open in 13.
Aaron Star
Re: Vegas 14 render issues, problems, crash, Vegas 13 fine
on Jan 30, 2017 at 11:01:02 pm
Just to be clear. What is your project settings, source media type, and render as profile you are using?
What are your system specs?
I am sure it work on VP13, just would like to know what type of settings and hardware you are having trouble with.
MIke Francis
on Jan 31, 2017 at 3:42:12 pm
windows Pro 10
32 gigs of ram
intel xeon cpu e-5 - 2687w @ 3.10ghz
64 bit
nvidia gtx970
nvidia k2000
rendering a pro res light files to mpeg 4
average video is about 2hrs long
Graham Bernard
on Jan 31, 2017 at 4:10:17 am
[MIke Francis] "I do long meetings and Vegas 14 is crashing all the time during render unless the project is under 1/2 hr....... Vegas 13 on the same computer is fine. "
Are you rendering to the same Hard Drive for VP14 and VP13?
* Grazie
MIke Francis
on Jan 31, 2017 at 3:35:07 pm
Yes ... all is the same ... even the same project .....but Vegas 14 crashes in render. Vegas 13 rocks. I guess no one renders hours of video so no fix.
Graham Bernard
on Jan 31, 2017 at 4:17:34 pm
[MIke Francis] "I guess no one renders hours of video so no fix."
I doubt that's correct. Let's see from others.
* Grazie
MIke Francis
on Jan 31, 2017 at 7:03:08 pm
I hope so Graham .... I sure would like to be able to use the $500 software I purchased. And since I have been using Vegas before Sony got it. I have years invested in using Vegas...all the way back when Sonic Foundry owned it. I even became a Sony Certified editor. I flew to a course the guys from VASST did and took the Sony Factory Certified test.... I would like to continue with Vegas. Otherwise its off to something else.
Aaron Star
on Jan 31, 2017 at 7:51:47 pm
Some else recently was complaining about rendering on Xeon. I wonder if there is an issue/bug there?
GPU acceleration enabled, or software only? NV cards are not great with Vegas.
Having you run your machine through clean up steps listed in other posts? Verified your memory is not overclock and 100% free of errors?
MIke Francis
on Jan 31, 2017 at 9:13:37 pm
Never had a problem with Vegas 13 and the GPU slows down render for me so it is turned off.
Lutz Godau
on Jan 31, 2017 at 11:15:50 pm
I have a Xeon 1231 3.4 and render videos longer than 30 minutes a lot on Vegas 13 and 14. Xeon ist a perfect workhorse for me. But I use a Radeon R290.
MIke Francis
on Feb 1, 2017 at 2:39:14 pm
maybe as a test you could try to render 3 hrs of video and see if it crashes.
