Sony Vegas Pro 13 render to Windows AVI?
COW Forums : VEGAS Pro
Ric Kemp
on Jan 22, 2017 at 9:56:51 pm
I'd like to render some video I have edited in Pro 13 to Windows avi but that option is greyed out (along with numerous options I notice). How do I enable rendering to Windows avi please?
Thanks.
Francois Pénzes
Re: Sony Vegas Pro 13 render to Windows AVI?
on Jan 24, 2017 at 11:27:37 am
Hi Ric
In Render As , bottom left corner checkmark the box for View all options.
Go to the right of the Search render templates box and click on More filter options (in blue)
Also, uncheck Show favorites only and Match project settings.
You may have to play with some of those not knowing what your original file is made of.
See if that helps. Let us know.
Cheers !
PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
''When the cutting stops, the editing begins...''
Ric Kemp
on Jan 24, 2017 at 2:15:11 pm
Thanks Francois,
Can't see my original post here so am a bit in the dark.
The avi option was greyed out because it is a drop-down but it doesn't tell you that. By trial and error (basically mouse-bashing) I got the drop-down menu to drop where it gives you the detailed avi options which are not greyed out ☺
Filters are okay at the moment - have used brightness and colour correction plus a 3rd party deflicker demo filter - all have rendered alright so far.
My source is captured home-movie cine, it is also experimental footage, not straight regular visuals.
How do I select 3:4 ratio in Vegas please, I use old cine cameras with original lenses so it's all 3:4 format.
Thanks again,
Ric
Francois Pénzes
on Jan 25, 2017 at 11:53:09 am
Hi Ric
I am going to assume that you meant 4:3 for the aspect ratio and that you are operating with the NTSC standard. If you are in PAL, apply these steps to PAL standard.
Open Vegas and first go to File / Properties
Change Template to NTSC DV (720x480, 29.970 fps)
Other pertinent settings are at your discretion.
Apply and OK
Import video
Click on Event Pan/Crop
Right click on image
Choose Match Output Aspect
Close window
Make sure that you Render settings match your project.
Here's a link to a handy Aspect Ratio Calculator
http://calculateaspectratio.com/
Cheers !
Ric Kemp
on Jan 25, 2017 at 3:21:58 pm
Many thanks Francois! ☺
What is the best PAL render for the Internet please? I also have enormous difficulty getting softwares to upload files, I often have to save a project as a file then manually upload to host sites.
Ric
Francois Pénzes
on Jan 26, 2017 at 12:58:06 am
Hi Ric
Pls follow this link. It should cover most of your questions.
https://support.google.com/youtube/topic/2888648?hl=en
Happy upload !
