Bending a line
COW Forums : VEGAS Pro
Ángel Molina López
Bending a line
on Jan 4, 2017 at 5:12:42 pm
Hi everyone:
I can't find anything about this effect so I have to ask you. How can I bend a line as the example below while it's moving around the comp?
Thx.
Video curve line
Graham Bernard
Re: Bending a line
on Jan 4, 2017 at 5:55:41 pm
[Ángel Molina López] "How can I bend a line as the example below while it's moving around the comp?"
In VP? Quick answer, no. Longer answer? Noooooooo...... Yes in VP we can Distort and Deform stuff, but this type of outcome is best suited to a package that does it straight off the bat.
* Grazie
Ángel Molina López
Re: Bending a line
on Jan 4, 2017 at 8:20:46 pm
Oh my god sorry hahahahaha but I've post in the wrong forum xd. I didn't realize about it.
László Kovács
Re: Bending a line
on Jan 4, 2017 at 8:20:52 pm
Well, you could take solid white, than create the line with cropping that solid white using bezier mask.
Then animate that mask using keyframes.
That could work, if you have huge lot of time and patience.
Graham is right, this is not something to do in Vegas.
Best regards
László Kovács
James Ollick
Re: Bending a line
on Jan 5, 2017 at 3:16:14 pm
I would try Boris BCC Continuum Units 3D Objects which works well within Vegas. It is a very flexible plug-in. I have been experimenting with it and they have many tutorials on their web site. Of course it would all be done with key frames but I believe it is doable.
James Ollick
