Vegas crashing when applying vegas stabilization to 4K video
COW Forums : VEGAS Pro
Ramon Trotman
on Dec 30, 2016 at 1:41:47 pm
Good day, I am looking for some help. When applying the vegas stabilize filter to help smooth out some of my panning 4K shots, Vegas crashes before completing the task.
I've tried the process with 1080 footage and it works well, but when trying with 4K, it crashes. I've tried enabling and disabling GPU acceleration, but the issue remains. Has anyone else ran across this issue?
Error details below:
Extra Information
File: C:\Users\Ramon\AppData\Local\VEGAS Pro\14.0\dx_video_grovel_x64.log
File: C:\Users\Ramon\AppData\Local\VEGAS Pro\14.0\svfx_video_grovel_x64.log
File: C:\Users\Ramon\AppData\Local\VEGAS Pro\14.0\ocio_x64.log
File: C:\Users\Ramon\AppData\Local\VEGAS Pro\14.0\dx_grovel_x64.log
File: C:\Users\Ramon\AppData\Local\VEGAS Pro\14.0\gpu_video_x64.log
File: E:\Video production\full frame vs crop\Full Frame camera really that much better.veg
Problem Description
Application Name: VEGAS Pro
Application Version: Version 14.0 (Build 161) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\VEGAS\VEGAS Pro 14.0\proDADMercalli20.dll
Fault Address: 0x00007FFA59126B36
Fault Offset: 0x0000000000046B36
Fault Process Details
Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
Process Version: Version 14.0 (Build 161) 64-bit
Process Description: VEGAS Pro
Process Image Date: 2016-09-13 (Tue Sep 13) 20:47:24
Ole Kristiansen
Re: Vegas crashing when applying vegas stabilization to 4K video
on Dec 30, 2016 at 3:23:12 pm
Hi Ramon
1. Update your Vegas Pro 14 to build 211
Ramon Trotman
on Dec 30, 2016 at 4:55:49 pm
Hey Ole, i've updated to build 211, the issue is still happening.
Ole Kristiansen
on Dec 30, 2016 at 5:51:26 pm
2. Your computer specs. ?
3. Mediainfo of your footage ?
Mark Wilson
on Dec 31, 2016 at 8:28:53 pm
Old mercalli 2 (the one native to last few vegas versions) does not support 4k - it crashes.
You need to upgrade to mercalli v4 either by buying vegas 14 with mercalli or if using vegas 14 "edit" version then get it from ProDAD (or sometimes vegasaur site has a deal).
