Setting Audio Codec Sony Vegas records with?
COW Forums : VEGAS Pro
Frankie Jones
on Dec 22, 2016 at 11:44:28 pm
Hey,
I wondered if it was possible to set the audio codec Vegas records with when the Record button is pressed.
In Dxtory for example there is a list of possible recording codecs:
Are these selectable within Vegas somewhere, or does Vegas just use it's own codec for recording.
Graham Bernard
Re: Setting Audio Codec Sony Vegas records with?
on Dec 23, 2016 at 11:19:15 am
Never bothered to question this.
* Grazie
John Rofrano
on Dec 25, 2016 at 6:56:49 pm
It is not possible to set the audio codec because Vegas Pro always uses the highest quality which is to record PCM which doesn't use a codec at all.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Aaron Star
on Dec 26, 2016 at 10:54:15 pm
John is right.
I would add that you set your recording format in the audio hardware normally. You use the driver applications that came with your hardware to set record format, then you simple select the device or interfaces inside Vegas to record. That goes for the stock onboard audio interfaces also. If that makes any sense.
You should be able to search this forum, or other posts on Magix's forum for people trying to use pro audio interfaces with Vegas. I know there have been several posts over the years on this topic.
