How to make the clips add to the project to automatically get croped to their last 30 seconds
COW Forums : VEGAS Pro
Lord Porongus
on Dec 21, 2016 at 10:59:24 pm
Hey there! I'm basically a novice with Vegas Pro 14 and I'm in need of some help. I'm making a compilation video so I have these 90 clips that I have to add and then cut. From these 5 minutes long clip I only need the last 10 seconds of each.
So my question is... Is there a way to set Vegas to automatically cut new added clips in a specific way? Or even select the clips in the project and cut them all at once?
László Kovács
Re: How to make the clips add to the project to automatically get croped to their last 30 seconds
on Dec 22, 2016 at 9:04:33 am
As always, if it's a repetitive tedious task, there's a high chance that Vegasaur can help you.
This is true for you as well :))
That setup will keep only the very last 10 seconds of your selected events.
After that, you can remove gaps, also doable with Vegasaur :)
Best regards
László Kovács
Lord Porongus
on Dec 23, 2016 at 4:55:38 pm
I'll check it out. Thanks!
