Import .ARW photo in Sony Vegas
COW Forums : VEGAS Pro
Nino Pericoli
on Dec 19, 2016 at 11:29:30 am
Hi!I need a trick or plugin to import my .ARW photo in sony vegas 13.I'm speedy to masking and edit compared to photoshop.Unfortunately vegas seem to work jpg only.Someone has solutions?
Graham Bernard
Re: Import .ARW photo in Sony Vegas
on Dec 19, 2016 at 11:35:59 am
[Nino Pericoli] "I need a trick or plugin to import my .ARW photo in sony vegas 13"
What's that format? I haven't heard of an ARW Photo.
* Grazie
Ole Kristiansen
on Dec 19, 2016 at 11:47:20 am
I think the .arw is from a Sony Nex camera !
Vegas pro work well with .png !
Graham Bernard
on Dec 19, 2016 at 12:11:03 pm
Will Vegas import those files then?
* Grazie
Nino Pericoli
on Dec 19, 2016 at 12:34:19 pm
Yes,from Sony Camera(a6300).If i convert to png i loose the benefit of a raw format edit,probably...
Aaron Star
on Dec 19, 2016 at 3:00:49 pm
You could convert your raw format to EXR. That format will hold all of your raw information, given your conversion software does not clip your info in the processing.
You could also convert to Photoshop format, as vegas works well with Photoshop files very well.
Nino Pericoli
on Dec 19, 2016 at 7:35:20 pm
Thanks Aaron. Which is the best converter i can use to transform? Is better exr or photoshop format?
Marco Baer
on Dec 19, 2016 at 9:53:14 pm
You could also install the Microsoft Camera Codec Pack which installs various RAW codec and which should enable you to import and edit .ARW files natively in Vegas Pro.
Nino Pericoli
on Dec 19, 2016 at 10:13:30 pm
Meantime i've tried Reaconverter 7 and wow!Works very well!I can transform .arw files in all formats (psd included)!
Aaron Star
on Dec 19, 2016 at 10:20:24 pm
+1 to Marco Baer comment too. I forgot about that option.
Nino Pericoli
on Dec 19, 2016 at 10:53:43 pm
Microsoft Camera Codec Pack not work on my win 8.1
Aaron Star
on Dec 19, 2016 at 11:13:14 pm
Photoshop might be easier to understand the workflow. EXR requires another level of understanding of image processing, but it is the best.
Marco Baer
on Dec 20, 2016 at 8:41:20 am
There's one especially for Windows 8.1:
https://www.microsoft.com/en-us/download/details.aspx?id=41337
Graham Bernard
on Dec 20, 2016 at 7:00:53 am
[Nino Pericoli] "Yes,from Sony Camera(a6300)"
Have you look at the Capture ONE s/w? Your camera is listed. Check it out. https://www.phaseone.com/en/Products/Software/Capture-One-for-Sony/Sony-Pro...
* Grazie
