Rendering XVAC-S video too slow!!!
COW Forums : VEGAS Pro
Suhaib Siddiqi
on Dec 13, 2016 at 11:47:39 pm
I have 1:30 hour long 4 K video recorded by Sony AX100. MAGIX Vegas v14 is taking more than 30 hours to render it as XVC-S. It is first time, I am using Vegas v14 for such a long 4K video.
I had several times rendered similarly long 4K videos on Sony Vegas 13, which took somewhere 10-12 hours on the same computer.
BTW: I am Windows 10 64 Bit, 1 TB SSD, 32 GB RAM and 16 Gb video RAM, Intel i7 (Skylake).
Aaron Star
Re: Rendering XVAC-S video too slow!!!
on Dec 14, 2016 at 6:48:31 am
Are you sure your source media, project settings, and output render settings are all the same?
Is there any heavy color correction, or effects on the time line media, that the system has to calculate before sending frames to the encoder?
Create a test project, where you encode your camera source to XAVC-intra, then run a test render on 1min or 10mins of footage. Then note the time difference and extrapolate for 1h30m.
