Pro 13 rendering error message / single minute of rendering without the crash / suggestions
COW Forums : VEGAS Pro
Brent Holland
on Dec 6, 2016 at 9:30:49 am
Pro 13
I keep getting the following error message. I can't even get through a single minute of rendering without the crash. Suggestions?
Extra Information
File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\dx_video_grovel_x64.log
File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\svfx_video_grovel_x64.log
File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\ocio_x64.log
File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\dx_grovel_x64.log
File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\gpu_video_x64.log
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 453) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Fault Address: 0x0000000000000000
Fault Offset: 0x0000000000000000
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 453) 64-bit
Process Description: Vegas Pro
Process Image Date: 2015-06-05 (Fri Jun 05) 21:53:04
László Kovács
Re: Pro 13 rendering error message / single minute of rendering without the crash / suggestions
on Dec 6, 2016 at 10:59:12 am
did you try to disable GPU support?
If that helps, download and give a try to Vegas 14. (Major bugs related to GPU support are fixed in the Magix version).
If GPU disabling does not help, you may want to give more details to the community about your project properties, source medias, and to what format you try to render to.
Best regards
László Kovács
Brent Holland
on Dec 6, 2016 at 11:24:06 am
Thx for the quick response.
How do I disable GPU support in Pro 13. Thx in advance
László Kovács
on Dec 6, 2016 at 11:32:39 am
In options / preferences.
Then on the video tab:
"GPU acceleration...." set it to off, then restart Vegas.
Best regards
László Kovács
Brent Holland
on Dec 6, 2016 at 11:37:52 am
Thx buddy, giving it a shot right now, off to bed close to 7 am in eastern canada (Kingston), see how far it gets while I'm sleeping
László Kovács
on Dec 6, 2016 at 11:45:33 am
You're welcome, especially if I could help.
Just took my lunch break here (Central Europe)
:D
Best regards
László Kovács
