SV ProDAD Stabilization Plugin for Clip NOT timeline event?
COW Forums : VEGAS Pro
Matthew Jeschke
on Nov 28, 2016 at 9:08:26 pm
I want to stabilize a clip. NOT an event in the timeline. The Prodad plug-in does not respond when adding it to a clip from the Project Media tab. See attached screen captures.
Reason is, this will reduce my workflow. Whenever I adjust in and out points on the timeline the stabilization makes me re-run. I'd ignore till the end of the project but their reminder to stabilize is so large you cannot see the clip *sigh*
Short rant I am not too excited about Magix support. Wrote them and mercalli same question about the new sony vegas stabilization plugin. Magix did not even read my question, the responded with the problem I wrote them and said add the effect to the timeline event *sigh* Prodad told me to read the manual :(
I do Architectural Photograph & Cinematography as a part of being a Residential Real Estate Consultant.
Some of my work can be seen at,
http://www.youtube.com/keystoaz/
http://www.keystoaz.com/
PS. It's an excellent excuse to ride of what I love, Camera equipment :)
Paul Berk
Re: SV ProDAD Stabilization Plugin for Clip NOT timeline event?
on Nov 29, 2016 at 6:10:24 am
Workaround is to stabilize the event and then render it to a lossless file format (like mxf). Use this stabilized file in your project. Personally, I don't do this as I can generally work around the Mercalli banner by removing the Mercalli and then adding it back once the edit is final. This is not hard to do if you work in smaller sections (say 5 min or so) . It would be a huge pain in an hour long timeline with numerous shots to stabilize.
Matthew Jeschke
on Nov 29, 2016 at 5:06:52 pm
Yeah I had thought about adding the effect in the final render. I actually have the stand alone version of Mercalli ProDad as well but it only outputs in two or three formats and makes for a HUGE project folder when you stabilize as they do not compress much. I have not known how to tell their tech staff... but they are frustrating. I have wrote them twice now with similar responses.
Steve Rhoden
on Nov 29, 2016 at 7:33:05 pm
Hopefully Prodad will update Mercalli to address such feature soon, in the mean time, and as you have the
standalone version, why not simply stabilize your shots first, then drop them on your timeline when doing
your edits then!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Matthew Jeschke
on Dec 5, 2016 at 6:17:21 am
I have thought of using the standalone version then editing those on the timeline. Maybe by the time my new editing machine is built they will have the issues fixed ☺
Glad it's not me though as Mercalli said, "Read the manual" when I contacted tech support. Made me think I didn't know what I was doing ☺
http://www.vimeo.com/matthewjeschke/
PS. It's an excellent excuse to ride off what I love, Camera equipment :)
