Disappearing audio/waveforms (?) - Vegas Pro 13
COW Forums : VEGAS Pro
Christian Mikkelsen
on Nov 27, 2016 at 2:49:15 am
Hello!
So for the past few months I've been having an extremely frustrating issue bothering me.
The problem is basically disappearing audio, as weird as that sounds. Sometimes an audio clip will take sound from another clip, other times there's no audio at all.
I can visually see this, when I scroll to zoom in on my audio wave forms, like seen in these gifs:
https://i.gyazo.com/199b0ee3ce4ec577338b14e52a73185c.mp4
(Zoomed out you see the original waveforms, but zoomed in it takes audio from another track and plays this in its place.)
https://i.gyazo.com/b929c5464d52ae3cc89615400149f9d2.mp4
(Here the audio compeltely shifts and repositions itself)
During playback, the audio does not play what its originally intended to, and the only real fix I've found is just restarting Vegas until I somehow can work in peace for 5 minutes before the same begins again.
These are completely normal .mp3 and .wav files that I work with.
Here are my PC specs, should it carry any significance;
Windows 10 Pro
Intel i7 4770k 3.5GHz
16GB ram
GeForce GTX 970
Any other relevant information I'd be glad to provide!
I would love to know if anyone else has experienced something similar to this and if there's any solution to this nightmare.
Thank you.
Ole Kristiansen
Re: Disappearing audio/waveforms (?) - Vegas Pro 13
on Nov 27, 2016 at 10:05:33 am
Do you have the mediainfo of your footage ?
Where do you live ?
Christian Mikkelsen
on Nov 27, 2016 at 2:21:54 pm
I haven't added any video files yet, but this is what I currently have imported to my timeline;
- a stereo .mp3 music track; 44,100Hz, 320Kbps
- an stereo .wav commentary track; 44,100Hz, 16 bit
- an ambient .wav track; 44,100Hz, 16 bit
Ole Kristiansen
on Nov 27, 2016 at 3:07:05 pm
Can you import, to the timeline, one by one and play with out problems ?
Christian Mikkelsen
on Nov 27, 2016 at 3:26:25 pm
I tried making a new project file, then added the music (.mp3), which worked just fine by itself. Then I added the commentary track (.wav), seemed alright. Finally adding the ambient sound (also .wav) and playing them all together worked just fine the first time around.
Merely seconds after playback this is what it looks like; https://i.gyazo.com/7b1c53dc890329e0e2a83c784afd154c.mp4
Adding them one by one, seems to work for a limited time before they somehow "merge" (?) I'm honestly baffled and having a hard time explaining myself.
The problem just appears out of nowhere it seems. Could it be that Vegas isn't fond of working with both mp3 and wav formats at the same time?
Ole Kristiansen
on Nov 27, 2016 at 3:42:59 pm
If you go to: Options - Preferences - Audio Device
Is it set to: Windows Classic Wave Driver ?
Christian Mikkelsen
on Nov 27, 2016 at 3:47:33 pm
It's set to 'Microsoft Sound Mapper'.
These are all my Audio Device settings; https://gyazo.com/dd6cc0f0d35d5aad459bc46715a31e1a
Ole Kristiansen
on Nov 27, 2016 at 3:53:19 pm
What if you change to Windows Classic ?
Christian Mikkelsen
on Nov 27, 2016 at 4:01:41 pm
Unfortunately it didn't seem to change or fix anything..
rosh kadri
on Nov 27, 2016 at 5:02:24 pm
I would report this to Magix, I'm having a similar problem with a disappearing explorer window too. I'm on build 201 fyi, is that what you have?
Christian Mikkelsen
on Nov 27, 2016 at 7:30:05 pm
Will definitely try to make them aware of it! I'm currently on build 310. Apart from this issue I rarely encounter anything else.
Ole Kristiansen
on Nov 28, 2016 at 9:05:35 am
It will probably be a little difficult to give blame Magix - it's Sony who made your version !
Why have you not upgraded to Sony Vegas Pro 13 build 453 ?
"So for the past few months I've been having an extremely frustrating issue"
After you upgraded to Windows 10 ?
Christian Mikkelsen
on Nov 28, 2016 at 11:44:31 am
I upgraded to 453 last night, but the issue still persists..
