vegas pro 14 having color issues at the beginning
COW Forums : VEGAS Pro
yasin ulu
on Nov 26, 2016 at 12:13:40 pm
im just having weird color problems every beginning of the cuts. it happens few seconds then i see no problem.
i dont have any problem like that on vegas pro 13
(happens beginning of the cuts.)
please check the images for better detail
László Kovács
Re: vegas pro 14 having color issues at the beginning
on Nov 26, 2016 at 1:32:57 pm
I don't see the problem. Can you post an image, where everything is fine?
Best regards
László Kovács
yasin ulu
on Nov 26, 2016 at 2:38:43 pm
above one is normal
other one i have problem with i tried to zoom for better understanding
those happens every 2 second
yasin ulu
on Nov 26, 2016 at 2:41:00 pm
here is more
Ole Kristiansen
on Nov 26, 2016 at 3:14:30 pm
Did you disable resample - and use constant bit rate - when you render ?
yasin ulu
on Nov 26, 2016 at 3:34:10 pm
sir when i disable resample it doesnt do anything , still having same problem .
for other things you said i didnt understand can you explain more detailed?
also when i render video its still the same like in the preview . having same issues on rendered video too, thats how it looks like :)
Ole Kristiansen
on Nov 26, 2016 at 3:50:24 pm
Ole Kristiansen
on Nov 26, 2016 at 4:28:46 pm
Why is your Project Settings: Frame Rate 59,607P ?
Try Frame Rate: 59,940 or 60,000
yasin ulu
on Nov 26, 2016 at 4:29:49 pm
but this is rendering step isnt it?
how can i fix that problem when im previewing the video?
the settings you said i wasnt using it like that , however i rendered the video with the settings you show me
it takes too long to render , also problem still continues :)
Ole Kristiansen
on Nov 27, 2016 at 8:05:50 am
Yes, the constant bit rate is for rendering !
Do you have the mediainfo of your footage and a image of your project settings in Vegas ?
