Vegas 14 crashes on startup
COW Forums : VEGAS Pro
Nicholas Ibarrientos
on Nov 10, 2016 at 1:11:22 am
Hello, I have been encountering a problem with Vegas 14. Upon loading the window, it says that Vegas has stopped working. Here is my error report.
Problem Description
Application Name: VEGAS Pro
Application Version: Version 14.0 (Build 189) 64-bit
Problem: Unmanaged Exception (0xe0434352)
Fault Module: C:\Windows\system32\KERNELBASE.dll
Fault Address: 0x000007FEFD48A49D
Fault Offset: 0x000000000000A49D
Fault Process Details
Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
Process Version: Version 14.0 (Build 189) 64-bit
Process Description: VEGAS Pro
Process Image Date: 2016-10-25 (Tue Oct 25) 19:39:54
I tried updating and reinstalling but it didn't work. Hope to get it working again.
I have a Dell T5500 with one Xeon Processor and WIndows 7. I'll get more info if needed.
EDIT:
I have deduced that it is a plugin problem involving the following plugins: compoundplug, mcmp4plug, and qt7plug. Any clue on what these plugins are and if they are essential for editing and rendering?
The directory where they were found are at C:Program FilesVEGASVEGAS Pro 14.0FileIO Plug-Ins
László Kovács
Re: Vegas 14 crashes on startup
on Nov 10, 2016 at 7:35:27 pm
Those are the file format plugins of Vegas.
Is there a project that Vegas tries to open at startup?
May it contain defect files?
Best regards
László Kovács
George Dean
on Nov 10, 2016 at 9:00:07 pm
Did you reset Vegas? WIth previous versions, on the desktop icon Hold down Ctrl+Shift, double click the Vegas icon. It's important to check, delete cached data, then Yes to reset. This will set Vegas back to default install values.
Best Regards.....George
