[Vegas 12] Is there any way I can automatically keep the image's original size when I insert to the video?
COW Forums : VEGAS Pro
tony chen
on Nov 9, 2016 at 3:34:22 pm
So let's say I want to insert an image that's 200x200. My video is 1920x1080. Whenever I insert it, it seems to zoom it to a larger size. Is there a way by default I can make it so that it keeps the original image's size?
I know panning/cropping and dragging does work but that's time consuming when having to place lots of images.
Graham Bernard
Re: [Vegas 12] Is there any way I can automatically keep the image's original size when I insert to the video?
on Nov 9, 2016 at 5:13:12 pm
[tony chen] " Is there a way by default I can make it so that it keeps the original image's size?"
Yes, uncheck Auto Crop in Preferences:
* Grazie
tony chen
on Nov 16, 2016 at 12:57:59 am
For some reason, I did what you did but it still showed my images across the whole screen. It might be because of the preview window right? I dont want to have to keep pan/crop every single image I put on the screen
Aleksey Tarasov
on Nov 9, 2016 at 6:43:24 pm
Automatically? No.
Correct it with a script? Yes.
Graham Bernard
on Nov 10, 2016 at 11:13:35 am
[Aleksey Tarasov] "Automatically? No."
Was I incorrect in my advise?
* Grazie
Aleksey Tarasov
on Nov 10, 2016 at 11:40:28 am
As I understand, OP wants a small image remained small on the screen (in its native resolution), like this:
Auto Crop option is used to make images match the output frame size by cropping it.
Graham Bernard
on Nov 10, 2016 at 12:23:29 pm
Yes, I know what was wanted. Turn Off or uncheck auto crop.
* Grazie
Aleksey Tarasov
on Nov 10, 2016 at 12:24:57 pm
And this works?
Graham Bernard
on Nov 10, 2016 at 1:36:31 pm
[Aleksey Tarasov] "And this works?"
No. It will "fill" to largest dimension. Hmmm...
* Grazie
