Vegas 14 .Net Framework error
COW Forums : VEGAS Pro
Rick Hutson
on Nov 1, 2016 at 4:10:45 pm
Trying the trial Vegas 14. Installed and I get the Net.framework error. I am running Vegas 13 just fine and have never had this issue. I have done all the Microsoft diagnosis for .Net framework. Deleted it and reinstalled it. Nothing on the checks shows up as wrong. I've done SFC check and all my updates are up. I have a legit copy of Windows 7. No other apps are giving me an issue. The Magic support hasn't replied and it's been days.
Any ideas would be great.
Steve Rhoden
Re: Vegas 14 .Net Framework error
on Nov 1, 2016 at 4:51:04 pm
Check again and make sure you have installed the newest version of the .net framework and the
Microsoft Visual C ++ for your system....
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Rick Hutson
on Nov 1, 2016 at 5:25:50 pm
Tried that still getting the error.
I have tons of programs running and this is the only thing that won't run.
Steve Rhoden
on Nov 1, 2016 at 6:44:39 pm
ok, now hold down the Ctrl and shift keys together, continue holding while you start up Vegas...
Rick Hutson
on Nov 1, 2016 at 7:22:30 pm
No go on that either. I have exhausted all the Net Framework things. I do not get any errors in any of the tests. I have uninstalled them and installed incrementally up to the latest version.
In the Vegas 14 notes it said net Framework 4.0 or 4.5 was needed. Installed those and same errors. Tried the delete config data on all versions.
Vegas 13 works fine. It didn't work when I uninstalled the net framework. But when it was installed it worked.
So it appears to be some Vegas 14 error. Tried running as admin. Checked permissions and so on.
Alberto Sesana
on May 14, 2017 at 12:11:35 pm
I have the same problem with NET.framework error and I would like to know if anybody solved this trouble.
Thanks for your help.
Rick Hutson
on May 14, 2017 at 2:44:27 pm
I spent a couple of days on it. Tried every suggestion possible I could find.
I finally nuked the OS and installed new Windows and all my apps. PIA to do but I was stuck and it took less time to do the install than I spent trying to fix it.
Alberto Sesana
on May 14, 2017 at 2:47:13 pm
Thanks for your suggestion.
