Any simple fixes for video that is overexposed?
COW Forums : VEGAS Pro
John Lee
on Oct 30, 2016 at 3:22:18 am
Had to film some sports footage from a particular side, so I was forced to film with the sun shining in front of me. I've googled it, and most of the recommendations I've seen involve manually working with color curves, etc., but I can't seem to get it right.
Forgive me for being lazy, but is there a premade Video FX setting I can try that might make it at least better? Thanks.
Graham Bernard
Re: Any simple fixes for video that is overexposed?
on Oct 30, 2016 at 5:52:40 am
Even if you adjust with FXs, you're going to need to determine just how much clipping has ocurred. It may not be salvageable.
* Grazie
Frederic Baumann
on Oct 30, 2016 at 12:02:01 pm
Could you post a still of your clip to see how overexposed it is?
Best regards,
Frédéric
FBmn Software: Professional GPU-powered plug-ins to fix White Balance and Exposure issues in a few clics.
Color-matching made easy with the ColorMatch plug-in.
Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
Or about Keyframes? Watch this one. French version here.
Mike Kujbida
on Oct 30, 2016 at 1:43:41 pm
John, here's a technique I stumbled across on the Sony Vegas forum a few years ago that may be of some help.
Put 3 filters, "Invert" (at 100%), "Color Corrector", "Invert" (at 100%).
Then lift up the gamma of the color corrector in the middle.
This darkens highlights first, in the logarithmic fashion, more like a "iris closing" way.
You can also put a color corrector secondary to select reds and lower the gamma a bit.
Good luck :)
Mark Wilson
on Oct 30, 2016 at 6:47:38 pm
You could try making a duplicate clip (CTRL drag) and then compositing it on top of the original with a blend mode of multiply (mask) ... set that on track header .
Roger Bansemer
on Oct 31, 2016 at 9:12:22 pm
One way that works very well in helping overexposed footage is to:
1. put "levels" on your event and bring the levels down.
2. put "curves" on the same event and bring the levels back up with your curves.
That will bring back some of the blown out colors.
Roger Bansemer - PaintingAndTravel.com
