Transition Shortcut (Vegas 13)
COW Forums : VEGAS Pro
Joseph Abaji
on Oct 29, 2016 at 2:03:19 am
Right clicking a cross fade in timeline > transition opens a menu with possibilities of adding a "crossfade" with the num / on keyboard and also adding "most used" transitions. When I was using Vegas 11, I used to have my num / key add a specific transition (example: Vegas Flash) when my cursor was on a crossfade. Is it possible to have my num / key add a specific transition instead of just "crossfade" while putting my cursor on a crossfade (as I had it in Vegas 11). I'm currently using Vegas 13.
Thank you
Graham Bernard
Re: Transition Shortcut (Vegas 13)
on Oct 29, 2016 at 5:48:06 am
I'm assuming you tried it and it doesn't work? If you did, had you got NumLock "ON", on the keypad?
* Grazie
Roger Bansemer
on Oct 29, 2016 at 10:42:01 am
If you hold down the shift key when dragging a transition to your events, it will eliminate the fine tuning choices and simply drop the default transition on there. That saves time.
Roger
Roger Bansemer - PaintingAndTravel.com
