Able to burn dual layer DVDs but not dual layer Blu-Ray discs
COW Forums : VEGAS Pro
Dan Lindley
on Oct 19, 2016 at 8:17:23 pm
DVD Arch Pro 6 and newest build with Vegas 14 - Same issue.
For years I've been using DVDA burning dual layer standard DVDs. Easy Peezy.
But my 1st attempt burning DL blu-ray discs is failing with the error message saying not enough room on disc.
Properties are set to blu-ray and 50gb.
Disc space needed is only 73% of the 50 gigs.
I'm not being prompted to enter a Break Point.
End result is the "not enough space on the disc" error.
A quick search on my burner Pioneer BDR-205 seems to indicate it is compatible with dual layer BD discs.
Any advice? Thanks much. This forum rocks!
Steve Rhoden
Re: Able to burn dual layer DVDs but not dual layer Blu-Ray discs
on Oct 21, 2016 at 1:50:26 pm
I personally think that issue is a feature limitation of DVD Architect!
Further blu-ray and other features needs to be fine-tuned and updated in this tool.
Hopefully, Magix will do this soon.... Because Sony stopped paying any attention to many
of these software when they had them.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
robert strong
on Oct 21, 2016 at 5:35:40 pm
If you are able to render out to an ISO file, you should be able to use Image Burn to burn your BD-DL's.
