MVP 14 Save as issue
COW Forums : VEGAS Pro
Francois Pénzes
on Oct 7, 2016 at 7:23:31 pm
Hi !
Started to use MVP 14 and when I try to do a Save As, this is what I get:
Any ideas as to what is going on ?
''For God's sake Jim, I'm an editor not a Klingon code reader !!!''
Graham Bernard
Re: MVP 14 Save as issue
on Oct 8, 2016 at 2:21:00 am
That error is indicating some asset that has not been altered/changed from working in Sony VP to work in MAGIX VEGAS PRO.
* Grazie
Steve Rhoden
on Oct 8, 2016 at 6:14:58 am
Its as Graham said....
By the way, Do you have any version of Sony Vegas installed with your Magix Vegas 14?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Francois Pénzes
on Oct 9, 2016 at 1:17:39 am
Thanks for the reply guys.
I am running MVP 14 but I did re-install SVP 12 because MVP 14 was way to buggy. I am running V 14 once in a while thru different routine to see what I can do with it without it crashing. SVP 12 is way more reliable in order for me to meet deadlines.
Steve: In your opinion, the fact that I am running both could be a problem ? In the past, I was able to run different versions of SVP without any problems and that goes back to when I started with Vegas 3.
Graham: Could you elaborate on altered/changed assets ?
Thanks !
Graham Bernard
on Oct 9, 2016 at 5:23:55 am
[Francois Pénzes] " Could you elaborate on altered/changed assets ?"
For example, have you used any SONY Scripts that have not yet been edited/recompiled to work with MAGIX VP? I've had exactly this with a Script that hadn't yet been recompiled to work in MAGIX VP14.
* Grazie
Francois Pénzes
on Oct 9, 2016 at 9:21:45 am
Hi Graham
I haven't used and/or added any scripts. The only ones present are what comes pre-packaged with MVP 14.
I have to say that I am having a lot of problems with MVP 14. I have a couple of slow days coming up and I will be running as many scenarios as I can and send the findings to Magix. Hopefully, it will help them come up with solutions.
But in the meantime, I will stick to SVP 12.
Thank you for your time !
F.
Graham Bernard
on Oct 9, 2016 at 9:54:20 am
[Francois Pénzes] "Thank you for your time !"
And yet another satisfied customer. How do I do it?
* Grazie
Francois Pénzes
on Oct 9, 2016 at 11:39:38 am
My guess is you were born that way....
Cheers ! ...and Thx again !
