Shift B < Render to new track
COW Forums : VEGAS Pro
Derek Charles
on Oct 6, 2016 at 9:26:08 am
Shift B has given me freedom of smoother playback with a lot of cpu heavy plugins
I have just now discovered the option to render to new track -
This helps me out big time when I want to make sure stabilization and neat video don't mess up anything.
I'm shooting in XAVC-S - When I render to a new track to keep the absolute same high quality - Is it correct to render to
Sony XAVC / XAVC S .mxf .mp4
XAVC Long
or
XAVC S Long?
László Kovács
Re: Shift B < Render to new track
on Oct 6, 2016 at 10:24:38 am
I used to use shift-M in Vegas10 (selective prerender) very frequently.
In V14 I need it much less ?
That does not require a new track, renders the selected portion of timeline to a preview file.
I always use lagarith for that purpose, but I guess other codecs do it as well...
Best regards
László Kovács
Steve Rhoden
on Oct 6, 2016 at 12:18:57 pm
Yes, a lossless codec such as lagarith is the way to go.
Or uncompressed AVI (if you don't mind ridiculously large file sizes) lol
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Derek Charles
on Oct 6, 2016 at 11:48:00 pm
I'm not seeing lagarith anywhere
The main focus is just to have plugins and color correction etc on an event be done with and now I have that event to work with fresh. - I used to do all of my editing as close as possible then render the whole file to XAVC S Long then start chopping up the events again how I want them from the one big file - I realize now that its better time wise to just do that in the same timeline by rendering to a new track and deleting the previous event with a fresh one.
Since I'm not seeing lagarith anywhere is it Ok I still keep using the XAVC S .mxf files as the fresh events?
László Kovács
on Oct 7, 2016 at 7:06:24 am
[Derek Charles] "I'm not seeing lagarith anywhere"
you can get it here.
Best regards
László Kovács
Derek Charles
on Oct 7, 2016 at 11:57:51 am
The hyperlink doesn't work for me
The COW says 404
and has lost her way in the pasture.
I'm guessing if I just google it and see the download links - still don't know how to install in Vegas to render -
I don't see why me exporting to XAVC S is a bad idea -
Since I am shooting in the XAVC S codec it shouldn't it be lossless? Or if not, an unnoticeable amount?
Ole Kristiansen
on Oct 7, 2016 at 1:44:50 pm
First install you codecs on your computer and restart the computer.
If it is an .avi container - you will find the new codec in Video for Windows!
Derek Charles
on Oct 7, 2016 at 3:50:46 pm
Thanks I'll try that -
Since I am shooting in the XAVC S codec it shouldn't be lossless? Or if not, an unnoticeable amount? File size is a concern as well.
László Kovács
on Oct 7, 2016 at 5:07:19 pm
I'm sorry, I messed up the link with copy/paste.
Now I don't try to make it clickabel, just put here:
http://lags.leetcode.net/codec.html
So from here you can download lagarith.
I like it, because it compresses well, it is lossless, and extremely fast, and can use RGB (computer) colors
For sreencaptures, and intermediate renders I always use lagarith.
Best regards
László Kovács
