Rampant Chamber Effects - Anyone use with luck?
COW Forums : VEGAS Pro
Scott Francis
on Oct 5, 2016 at 6:48:59 pm
Hey All,
Purchased the Rampant Design Chamber FX (and numerous others as well0, MVP 14 will not allow me to drop them into my timeline. I had issue with them in SVP13 and just remuxed them in Avidemux to use them. I tried that this time and it throws me errors. Anyone had any luck with these and if so how?
Thanks for your help!
Xavier (Scott) Francis
Mind's Eye Audio/Video Productions
Scott Francis
Re: Rampant Chamber Effects - Anyone use with luck?
on Oct 5, 2016 at 6:52:54 pm
Here is what mediainfo gives me as far as data:
General
Complete name : I:\Rampant Mattes\New Purchase\Ink\Rampant_Mograph_Essentials_Ink_001.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 201 MiB
Duration : 33 s 867 ms
Overall bit rate mode : Variable
Overall bit rate : 49.7 Mb/s
Encoded date : UTC 2014-11-04 22:10:11
Tagged date : UTC 2014-11-04 22:14:32
Writing library : Apple QuickTime
©TIM : 10:35:19:20
©TSC : 2997
©TSZ : 125
Video
Format : ProRes
Format version : Version 1
Format profile : 4444
Codec ID : ap4h
Bit rate mode : Variable
Bit rate : 49.4 Mb/s
Width : 4 096 pixels
Height : 1 728 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Chroma subsampling : 4:4:4
Scan type : Progressive
Bits/(Pixel*Frame) : 0.291
Stream size : 200 MiB (100%)
Language : English
Tagged date : UTC 2014-11-04 22:10:11
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 10:35:19:20
Time code, striped : Yes
Language : English
Steve Rhoden
on Oct 6, 2016 at 12:06:55 pm
I have heard complaints over time about users of Vegas with the same issue you are having with Rampant,
but im not quite sure why this is so. I use many of Rampant's files without an issue, but i'm summarizing
that maybe due to the fact i have many a varied codecs installed on my work system.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Scott Francis
on Oct 6, 2016 at 2:00:05 pm
I have tried to save with Quicktime pro, avidemux and looks likeI MAY have found one of the "converter" in EZ Encode to work. It is REALLY frustrating to me as there are like hundreds of files and I have spent nearly 8 hours trying to convert them or get them to the correct format.
They are just so cool and I really need them for some of my projects, but this is really a pain.
Thanks for your input!
