Magic vegas pro 14 issue
COW Forums : VEGAS Pro
Henry Hefner
on Oct 2, 2016 at 10:22:47 am
i installed the new magix vegas pro 14 all went well
then when i tried to open up the prog it gave me this error
Problem Description
Application Name: VEGAS Pro
Application Version: Version 14.0 (Build 161) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Common Files\OFX\Plugins\NewBlueFX\Stylizers.ofx.bundle\Contents\Win64\Stylizers.ofx
Fault Address: 0x000000000836AE64
Fault Offset: 0x000000000009AE64
Fault Process Details
Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
Process Version: Version 14.0 (Build 161) 64-bit
Process Description: VEGAS Pro
Process Image Date: 2016-09-13 (Tue Sep 13) 14:47:24
Steve Rhoden
Re: Magic vegas pro 14 issue
on Oct 2, 2016 at 6:47:17 pm
the Newblue plugin you have installed is whats causing you this problem.
Uninstall it, then restart Vegas.... Is it Newblue Titler?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Henry Hefner
on Oct 2, 2016 at 6:51:42 pm
i installed it time ago the i unistalled it but it seems its still somewhere i guess
i did go to the map and just deleted it but it still didn't do a thing fo me
so imma try to find it
to be continued
Henry Hefner
on Oct 2, 2016 at 7:07:52 pm
yes it works now it was the newbleu ofx plus the transitions fx
and it started to work now
ithank you for the selution
you can't inmagine how grateful i am you made my day if i had 100 thumbs i would put them up all thnx
George Dean
on Oct 2, 2016 at 7:35:10 pm
Hi Henry,
The good news is you got your v14 up and running. The bad news is, you now know there are some problems with v14 playing well with NewBlue, or is that the other way around! The other good news is, as I understand it, NewBlue is working on a fix and hopes to have the solution available soon.
Best Regards.....George
Henry Hefner
on Oct 2, 2016 at 8:09:37 pm
well if thats the bad news as it is i take it as a man meaning we see as it goes but for now its good enough
so still 1000% thankfull for the first encounter with 14... i'm all good .....for now,,
Steve Rhoden
on Oct 2, 2016 at 8:44:35 pm
Glad its now up an running properly...
