SLOW Project Load -- Did V14 change File I/O routines? Crash on opening Render dialog.
COW Forums : VEGAS Pro
Rob Rothkopf
on Oct 2, 2016 at 3:02:56 am
I'm having two problems tonight with Vegas 14.
PROBLEM #1 SLOW project load
When loading my V14 project, it is taking *21 minutes* to load.
0-3% instant
@3% 11 minutes
@ 11% 10 minutes --> Timeline populates then and project seems loaded.
@ 3% my CPU was at 16% (Vegas using 15%), memory @ 28% and Disk I/O at 52 MB/s
When loaded fully, CPU was at 36% (Vegas using 33%), memory @ 56%.
I loaded a V10 version of this project into V10, and it loads instantly. (that version was from beginning of day -- since then I've tweaked LOTS of edits, audio envelopes, and added media effects (mostly color correct).
To assure it wasn't my changes, I then loaded that same V10 version of the project into V14 as a control. Similar results to my newer V14 version of that project.
0-6% 3 minutes
6%-11%->100% 11 minutes
Sat at 100% for another 11 minutes then the timeline loaded.
Problem #2 - CRASH when selecting "Render-As" menu
As soon as I choose -> , Vegas 14 crashes. (the dialog does come up shortly after the error reporting dialog appears.
If I start with an empty project, add something small (e.g. 5-seconds solid color media generator), then Render-As dialog opens just fine.
HELP!!!!!
László Kovács
Re: SLOW Project Load -- Did V14 change File I/O routines? Crash on opening Render dialog.
on Oct 2, 2016 at 7:53:44 pm
Do you use .mxf / .m2t files in your project accindentally?
If yes, I think you should report to Magix.
Best regards
László Kovács
László Kovács
on Oct 2, 2016 at 7:54:53 pm
Sorry, the link was not pasted:
https://forums.creativecow.net/thread/24/1013982#1013982
Best regards
László Kovács
Rob Rothkopf
on Oct 3, 2016 at 4:20:01 am
Not accidentally -- yes, there is one .M2T file in the project (actually two, but the "control" (old version of the project) with Vegas-10 and Vegas-14 only has one of the .M2T files in it, the "SAT_LEFT1" clip.
