Batch trim Start and end of every imported clip
COW Forums : VEGAS Pro
Joseph Abaji
on Oct 1, 2016 at 10:28:52 pm
Hello,
I'm trying to find a way to trip the first and last second of every clip imported in Vegas. I have no knowledge about the usage of scripts. I have the vegasaur plugin but don't know how to use it.
Thank you,
Wayne Waag
Re: Batch trim Start and end of every imported clip
on Oct 1, 2016 at 11:46:44 pm
Since you have Vegasaur, it's quite easy. Go to quick properties and select the events tab. You make your adjustments using the Take Offset and Length checkboxes. Set 1 sec in your offset, adjust length, and then under length select 1 sec and also select Decrease in the rightmost Dropdown box. Then apply to your selected event.
It's really worth learning to use all of the many features of Vegasaur--especially, since you've already paid for it.
wwaag
Joseph Abaji
on Oct 2, 2016 at 1:23:37 am
Great! Thanks!
