How to make DEFAULT multi-cam edit Cross-Fade instead of Cut?
COW Forums : VEGAS Pro
Rob Rothkopf
on Sep 25, 2016 at 4:11:33 pm
Is there a way to make the default "change-camera" action in Vegas 14 a Cross-Fade instead of Cut?
I understand I can press the Ctrl key down when clicking a camera (or typing the # when in multi-cam mode), but since ALL of my transitions for certain types of edits will be cross-fades, this is a major PIA.
ALSO (Enhancement Request) -- it would be an AMAZINGLY AWESOME enhancement to be able to setup alternate cross-fade lengths set in options, which could be activated with modifiers.
e.g.
Preferences Multi-cam Section options:
Default switch duration (0 = cut)
Medium switch duration: [ ]
Long switch duration: [ ]
Then, add switch modifiers so the editor can choose a default switch, medium, or long.
e.g. pressing 2 switches to camera 2 using the default duration
pressing switches to camera 2 using the Medium duration
pressing switches to camera 2 using the Long duration
