Vegas Pro 14 crashes when Exit
COW Forums : VEGAS Pro
Suhaib Siddiqi
on Sep 23, 2016 at 12:50:12 am
Strange behavior. I installed Demo version of Vegas Pro v14, with 30 days extended trial. All works great. Today when starting Vegas Pro 14, I got a pop-up from MAGIX that is buy upgrade for $199.00. I purchased upgrade at $199.00. Vegas Pro v14 works great till I render and quit (File --> Exit) Vegas. I get Kernel fault.
BTW: My laptop is Acer V17N, with Intel Skylake, 32 GB RAM and Nvidia 960M with 8 GB vid RAM, 1TB Internal SSD and a second 1TB HHD, 4K UHD display.
Problem Description
Application Name: VEGAS Pro
Application Version: Version 14.0 (Build 161) 64-bit
Problem: Unmanaged Exception (0xe0434352)
Fault Module: C:\WINDOWS\System32\KERNELBASE.dll
Fault Address: 0x00007FFC1EDF7788
Fault Offset: 0x0000000000017788
Fault Process Details
Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
Process Version: Version 14.0 (Build 161) 64-bit
Process Description: VEGAS Pro
Process Image Date: 2016-09-13 (Tue Sep 13) 20:47:24
Wayne Waag
Re: Vegas Pro 14 crashes when Exit
on Sep 23, 2016 at 1:58:50 am
Since you've already exited, there is nothing to worry about. This is a common occurrence in V13 and I guess it hasn't been fixed in V14. Just an annoyance.
wwaag
Suhaib Siddiqi
on Sep 23, 2016 at 2:04:04 am
Thanks for the response. I did understand that it was just an annoyance, as it was in v13. Demo version was working perfect till I activated with a serial number. I bought the Vegas Pro Edit, because I already have BCC and Titler Pro v4 latest versions, and the one which shipped with so-called Vegas Pro Suite are outdated ancient versions.
Regardless, when I had this issue with v13, I did a layout reset to default. Let's see if it helps with v14.
Steve Rhoden
on Sep 25, 2016 at 11:57:03 am
Yeah, that often happens. did the layout reset to default helped?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Suhaib Siddiqi
on Sep 25, 2016 at 1:40:02 pm
Maybe, I did Layout reset as I always did with v13. Although, in case of v14, I had not changed anything Layout. So far I had rendered over 50 clips and no annoying crash when Exiting v14.
Suhaib Siddiqi
on Nov 4, 2016 at 10:17:43 pm
Now Vegas Pero 14 is crashing way too much. Sometimes it crashes in the mid of rendering a clip, sometime on exit, and other time while saving a project. v14 seems to be way too much buggy than v13. I do not think MAGIX has resources and capabilities for a professional software. They may be OK with consumers play tools for editing video. I feel pity for udating to v14. I am seriously considering moving to another NLE.
Francois Pénzes
on Nov 4, 2016 at 10:58:57 pm
Hi Suhaib
Try upgrading to latest version (189). It may solve your problem.
Cheers !
PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
''When the cutting stops, the editing begins...''
Suhaib Siddiqi
on Nov 7, 2016 at 8:56:47 pm
Ho Francois!
How do I do that? Vegas 14 does not have an update option, like most software do. MAGIX website has no information that new builds are available. Vegas 14v on start does not prompt that new builds/update are available. I do not believe MAGIX is qualified enough to maintain a software such as VEGAS!!!!
Francois Pénzes
on Nov 7, 2016 at 9:24:47 pm
https://forums.creativecow.net/thread/24/1014889
Suhaib Siddiqi
on Nov 7, 2016 at 9:30:13 pm
Thanks Francois,
I logged into my account and downloaded the installer. After updating, it prompted for SOfwtware license and re-registration of software, which is surprising! That means, each time I update to the newest build, one of my license key is going to be consumed? Very unprofessional way of applying an update!!!
