v14 - a list of supported GPUs anywhere?
COW Forums : VEGAS Pro
Peter Holt
on Sep 21, 2016 at 1:37:49 pm
Is the GTX750 Kalm 2GB card supported by v14?
It crashes v13 pretty well; one has to disable GPU everywhere possible to use the program.
I don't want to change the video card because this is the fastest fanless card on the market, and it plays 1080P 50FPS 50mbits/sec nicely.
László Kovács
Re: v14 - a list of supported GPUs anywhere?
on Sep 21, 2016 at 2:32:40 pm
Hmmm...
Not sure, does this help?
http://www.vegascreativesoftware.com/us/vegas-pro/specifications/#productMe...
Best regards
László Kovács
Peter Holt
on Sep 21, 2016 at 2:40:24 pm
For the GTXxxx (Nvidia) that just says
Requires a CUDA-enabled graphics card and driver 270.xx or later.
GeForce GPUs: GeForce GTX 4xx Series or higher (or GeForce GT 2xx Series or higher with driver 297.03 later).
Quadro GPUs: Quadro 600 or higher (or Quadro FX 1700 or higher with driver 297.03 or later).
which I strongly suspect is nonsense because mine "does" CUDA and is almost brand new but it still doesn't work.
John Rofrano
on Sep 23, 2016 at 5:31:25 pm
[Peter Holt] "which I strongly suspect is nonsense because mine "does" CUDA and is almost brand new but it still doesn't work."
What doesn't work? Vegas Pro timeline GPU acceleration uses OpenCL. To the extent that your NVIDIA card supports OpenCL it should work. ATI/AMD Radeon cards tend to support OpenCL better than NVIDIA so your performance might not be as good as an AMD card.
The Render GPU acceleration that does support CUDA only supports cards using the older Fermi architecture. It does not support any Kepler or newer cards. Basically that means the Geforce GTX 465 - 480, GTX 560 - 590 are supported and all other NVIDIA cards are not.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Aaron Star
on Sep 25, 2016 at 12:19:33 am
Because Vegas 13 timeline effects operate in a very similar way to Luxmark's rendering engine utilizes compute resources. Luxmark ranking generally offers a good view as to cards that will be best for Vegas.
http://www.anandtech.com/show/9621/the-amd-radeon-r9-nano-review/15
The latest version of Luxmark's render engine looks to have the NV1080 coming out way head of the Fury X, this may not mean that the 1080 will perform well in Vegas. Scores using the Luxmark engine 2.0 would be better scores to consider, since Vegas has not been updated in a long while. NV has been caught repairing benchmark operation for marketing reasons. Someone would have to test Vegas on the NV1080 then report the results. Anandtech has dropped Vegas as test benchmark since Magix bought the the software.
Peter Holt
on Sep 25, 2016 at 6:42:02 am
OK, thank you all. Looks like the GTX750 is not going to be supported. I have disabled GPU acceleration throughout; Pro 13 doesn't work otherwise.
John Norton
on Sep 25, 2016 at 2:11:29 pm
"ATI/AMD Radeon cards tend to support OpenCL better than NVIDIA so your performance might not be as good as an AMD card."
I understand that was some time ago, perhaps Nvidias OpenCl has got better over the years?
I don't have any axe to grind, Amd/Nvidia. Do you have any recent benchmarks that show AMD is still better at OpenCL than Nvidia, or is this just hearesay?
John Rofrano
on Sep 25, 2016 at 2:33:14 pm
[John Norton] "I understand that was some time ago, perhaps Nvidias OpenCl has got better over the years?"
This could very well be the case.
[John Norton] "I don't have any axe to grind, Amd/Nvidia. Do you have any recent benchmarks that show AMD is still better at OpenCL than Nvidia, or is this just hearesay?"
I don't follow benchmarks much and with OpenCL the difference between workstation class cards and gaming cards varies widely due to their different drivers. My comments are largely based on Vegas Pro users who have purchased both cards and prefer the performance they get from AMD Radeon cards. It seems that all of the Vegas Pro NVIDIA GeForce based customers are not as happy.
Here is a Vegas Pro benchmark from AnandTech showing AMD well above NVIDIA for performance:
I also did my own testing with Vegas Pro on two cards that are 100% supported, the NVIDIA Quadro 4000 and AMD Radeon HD 5870 and the AMD was the clear winner. Obviously these are 2010 cards because Vegas Pro doesn't support anything new than 2010 cards for GPU rendering. :(
~jr
Matthew Jeschke
on Dec 19, 2016 at 4:05:58 am
I am quite confused on the model numbers for Radeon. A while back you mentioned the R9 290 was a good card for vegas. Is it still king of the hill?
I do not use adobe for video... and rising SVP 14, some burris plug-ins, and just purchased Hit Film a few days ago. I dabble in DaVinci resolve as well.
Want something that can handle me throwing 4k raw at it... or at least a 1080p raw workflow without proxies.
I do Architectural Photograph & Cinematography as a part of being a Residential Real Estate Consultant.
Some of my work can be seen at,
http://www.youtube.com/keystoaz/
http://www.vimeo.com/matthewjeschke/
http://www.keystoaz.com/
PS. It's an excellent excuse to ride off what I love, Camera equipment :)
salim samou
on Dec 19, 2016 at 10:43:21 pm
John ,as of this day ,what would be the best gpu to buy for magicx 14 ,mainly for timeline 4K playback performance ,my main issue is lagging playback and having the ability to utilize the gpu (or as much as Vegas allows with its best supported card to date. ) ..rendering time is not important as I have lots of cores (32) on my system and lots of ram 96 .even with those timeline lags with pro res 4K files (hd or 2k not so much) .
Dave Haynie
on Dec 20, 2016 at 7:01:40 am
I recently upgraded my video card... a new 3440x1440 monitor joined my dual 2560x1440 monitors, and I needed a card to support 4K-class resolutions. I got an AMD Radeon RX480, currently replaing the old HD6970. I could technically have both in there, but haven't a reason yet.
I ran the red car benchmark... curious results.
Running full quality HD preview, it's like butter... not a glitch. And the GPU seems to be taking a nap, whereas my old one was running in the 36-40% range. But without a GPU, this is very stuttery, so definitely using the new GPU in there.
Then I ran a couple of renders. Rendering Sony AVC at 1080i60 and 16Mb/s gave me 1:36, versus the 1:34 I saw with the old card (though I didn't set up a clean benchmark environment with all other apps shut down)... essentially the same.
The MainConcept AVC render at 1080i60 and 25Mb/s was curious. I didn't see any CPU/GPU option in Vegas 14... either it's not there at all, or they finally don't show it if it can't help. Anyway, my system with the old GPU did it in 0:57 minutes... pretty fast. Without GPU, 5:19 minutes... these are all with 8-bit math. With the new GPU I got 3:09 minutes. So clearly, the AVC plug-in is not getting GPU acceleration, as expected. But the overall system Vegas system is.
-Dave
László Kovács
on Dec 20, 2016 at 7:16:40 am
[Dave Haynie] " I didn't see any CPU/GPU option in Vegas 14... either it's not there at all, or they finally don't show it if it can't help."
That option is there, just hidden by default. Look up in Option/preferences menu. Hold shift-ctrl while clicking "preferences", and there will be a tab "Internal". Do a search for "GPU" and set "Allow GPU Rendering" to true.
This will allow the GPU related render option to show up.
For me in the V14 the GPU rendering itself was enabled by default, just the option was hidden.
Best regards
László Kovács
Ole Kristiansen
on Dec 20, 2016 at 11:29:14 am
Hi László Kovács
"That option is there, just hidden by default."
There is and option in Vegas 14.0 Build 201 !
László Kovács
on Dec 20, 2016 at 3:04:45 pm
Wow, thanks for that! Nice catch! :)))
In build 161 it was not there, I didn't notice it appeared.
Best regards
László Kovács
Ole Kristiansen
on Dec 20, 2016 at 5:04:24 pm
I looked for something else and saw that it had come with the new build 201 !
best,
Ole
John Norton
on Dec 20, 2016 at 5:21:37 pm
Hi Dave Haynie, theres a small thread here going on here https://www.vegascreativesoftware.info/us/forum/nvidia-1080-video-card--104...
with some benchmarks and Magix 14, you might be interested.
Just like to thank you for doing a lot of the digging in the past RE: the Mainconcept limitations with modern gpu's, it was a great help.
