Is it possible to make your own Aspect Ratio Preset
COW Forums : VEGAS Pro
Sean McNally
on Sep 21, 2016 at 2:16:40 am
Hey there,
Using Vegas Pro 13 (from waaaaaay back when it was owned by sony, remember those days?)
Anyway, I love the pan/crop presets that allow for you to automatically crop to ratios like 1:1 or 16:9. I have a project where I need to crop individual objects to 8:5, which I could do the math for manually each time, but I frankly just don't want to. Is there any way I can make this shape into a preset for vegas?
Sean
László Kovács
Re: Is it possible to make your own Aspect Ratio Preset
on Sep 21, 2016 at 4:28:35 am
Definitely yes.
Setup your crop, name it, and save it.
That's all.
Best regards
László Kovács
Sean McNally
on Sep 21, 2016 at 4:53:24 am
Not quite. See, if you crop a 16:9 image to 8:5 and save that as a preset, that preset is only accurate for other 16:9 images. If you take, for example, a 4:3 image and try to use the same preset, it will not be accurate. Oddly though, the built-in Vegas aspect ratio presets (1:1, 4:3, 16:9) are always accurate regardless of the source aspect ratio.
László Kovács
on Sep 21, 2016 at 7:39:49 am
Ooops, sorry.
I wasn't aware of that.
Hmmm..
Could perhaps create a 8:5 preset for 4:3 images, and also another for 16:9?
Best regards
László Kovács
