I am currently downloading/installing Vegas pro 14!!! :)))
COW Forums : VEGAS Pro
László Kovács
on Sep 20, 2016 at 7:39:45 am
Best regards
László Kovács
Graham Bernard
Re: I am currently downloading/installing Vegas pro 14!!! :)))
on Sep 20, 2016 at 8:09:30 am
Are you using the Demo version? Or are you paying full price? Od have you got the Upgrade from purchasing VP13?
* Grazie
László Kovács
on Sep 20, 2016 at 8:16:53 am
It is still the demo version, but when it starts, it's possible to activate.
No, I didn't do it yet, because I have the old SCS format serial, which this program doesn't accept.
But I purchased the V13 with the promise that I'll get V14 for free, so I think I'll get a serial for this version soon.
I'm just trying it now with the 7 days option :)
After a quick test I can report, that at least those 2 bugs that broke my workflow with enabled GPU are resolved.
I liked the old colorful icon set better, but it's a matter of taste...
Best regards
László Kovács
László Kovács
on Sep 20, 2016 at 8:49:12 am
For rendering the GPU option seems to be gone. (I don't find it - maybe it's a limitation of the trial?)
The rendered file does not contain any watermark, so I think it's possible to use until the serial arrives ;)
Best regards
László Kovács
Graham Bernard
on Sep 20, 2016 at 9:51:57 am
Repro-ed.
GPU available in VP13 but not VP14 Build161.
* Grazie
Steve Rhoden
on Sep 20, 2016 at 11:29:25 am
What do you mean Graham?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Graham Bernard
on Sep 20, 2016 at 12:07:51 pm
Steve, in the Render As menu for those Templates that utilise GPU Rendering, the System Tab has a CHECK GPU. This appears in VP13 but not in VP14.
* Grazie
Steve Rhoden
on Sep 21, 2016 at 1:26:45 am
Interesting!
László Kovács
on Sep 20, 2016 at 12:08:34 pm
Hi Steve,
We are talking about GPU accelerated rendering. It seems to be gone, simply not present in Vegas14. Hopefully, it is removed just temporary.
It still has GPU acceleration for the timeline playback.
Today I finished a short project with the new V14.
It feels, that it is much more stable, than the V13, and I can:
-apply glow/shadow to a track even with zero blur :)
-crop an image to 1:1 or 4:3 without weird "jumping here and there"
while GPU is on. (The above things were impossible in Vegas 13 with GPU enabled)
So I have to say a big THANKS to Magix :)
Best regards
László Kovács
Graham Bernard
on Sep 20, 2016 at 12:12:29 pm
Hmmm... Try the Internal Settings and manually turn GPU ON. Just read this on the MAGIX VEGAS BETA Forum.
* Grazie
László Kovács
on Sep 20, 2016 at 12:22:09 pm
Wow, the option is there again. Thanks!!! :))
Based on my readings on task manager and gpu-z, seems that GPU accelerated render was ON by default, only the option was hidden.
Best regards
László Kovács
Scott Francis
on Sep 20, 2016 at 2:28:48 pm
What is your overall impression?
Is it SVP13 just with a few new things, or is it overall a better program?
GPU preview acceleration is paramount to me, as is stability and so forth.
Do any all of your third party FX work well? Did Magix add any new FX?
Thanks for your input!
Xavier (Scott) Francis
Mind's Eye Audio/Video Productions
László Kovács
on Sep 20, 2016 at 2:42:03 pm
Hi Scott,
My impression is, that V14 waaaay much more stable with enabled GPU than the 13 was.
I have few older projects I made in V10 but kept in case I need to rerender. Those were a complete mess in V13 if I didn't disable GPU - now that works flawless in V14.
I use just very few effects, such as color curves, color corrector mainly, but I'm fine with Vegas stock FX's.
So I can't tell about 3rd party FX anything.
Vegasaur stopped again, seems I have to buy the 3.0.
The interface changed a bit, it got a new BW icon set, which I don't like very much.
Otherways the main things stay as they were in the previous versions.
I mean, no need to re-learn, as it is the case with Microsofts modern concepts for example.
So if you change from V13 to V14 the first thing you'll notice is the BW icons on the UI.
The second thing you'll experience that GPU acceleration does work, and even better: it also seems to be useable
Give it a try!
Best regards
László Kovács
David Shirey
on Sep 20, 2016 at 5:12:26 pm
This is all very promising, thanks for your feedback and keep it coming if you discover anything else. Out of curiosity what GPU card do you have?
Now I just need to wait for Magix to offer me some sort of 13 -> 14 upgrade path.
László Kovács
on Sep 20, 2016 at 6:09:44 pm
It's a Radeon HD6970.
Best regards
László Kovács
John Norton
on Sep 20, 2016 at 7:32:57 pm
Have they, Magix, any info. on Graphic card support, render/timeline playback?
Don Cobble
on Sep 20, 2016 at 11:56:26 pm
I have downloaded the Trial V14, (This is on my PC2 editor specs below)
1) Pluraleyes 4.0.1 does not show up in MVP14 but does show up in SVP13 on same computer.
2) New Blue Titler Pro 4 ultimate crashed MVP14 but works on SVP13
3) Hitfilm Effects works ok so far on both
4) Newblue Color fast works on both so far
5) I am using Grass Valley HQX Codec 29P 10Bit footage - both SVP13 and MVP14 do some random funky pixilation stuff at different times so I see neither like that codec
6) Running 6 tracks of HQX in multicam - The MVP14 seems to manage multicam better than the SVP13
7) Rendered out Main Concept MP4 720P 2 Pass MVP14 with GPU on - no problems
8) Rendered HEVC 1920x1080 29P 12 mbps with GPU on - no problems
PC 1
I7 2.8 Ghz 16GB Ram
SSD 850 Pro OS drive
2x 850 EVO Raid 1TB
Win 7 Pro 64bit OS
XFX Radeon R9 290
PC 2
I7 3930K 3.2Ghz
32 GB Ram
2x 850 EVO Raid 1TB
3-4 TB HD
Win 10 Pro 64bit OS
GeForce GTX 960
IMAC Retina 5K 27in
4.Ghz i7 32gb Ram
AMD R9 M395X 4Mb
El Capitan
Magix Vegas 13 & Adobe Production Premium CS6 & -Edius 7.5 Pro - Edius WG Pro 8 - Sony Catalyst Production Suite - FCPX - DaVinchi Resolve 12.5
Camera
Sony EX1 shoot in 1920x1080 30P
Don Cobble
on Sep 21, 2016 at 12:18:08 am
MVP14 Real time - Preview Full - 6 Tracks - different levels of opacity so all six tracks are all visible - With different NewBlue and Hitfilm effects on each track. Plays back very good on the external 4K monitor
Graham Bernard
on Sep 21, 2016 at 1:30:10 am
Crucial feedback Don! Thanks.
* Grazie
Don Cobble
on Sep 21, 2016 at 2:16:00 am
8) Rendered HEVC 1920x1080 29P 12 mbps MOV with GPU on - no problems
Dave Limbaugh
on Sep 21, 2016 at 1:37:54 am
I'm a little concerned about the crash with Titler Pro 4. I had the same problem with both SVP13 and Hitfilm Pro 4. Turned out the order of installation was important for Vegas: remove TP4, install Vegas 13, then TP4. I also had to make all old versions/folders of Titler (Titler EX, etc) were off my disk and out of the VST plugins folder. Maybe this will work for you?
David Shirey
on Sep 21, 2016 at 2:18:37 am
Wow, I downloaded the trial on my home computer and it's crashing like crazy and running way worse than Vegas 11. It renders fine but if this isn't going to just run perfectly out of the box I don't think it's worth $200 and a day or two of troubleshooting. Glad most people don't seem to be having these problems though.
Don Cobble
on Sep 21, 2016 at 2:40:27 am
MVP14 is crashing now in multicam
I do not know what this means? but its looking like it will be a while to become stable - disappointed
Extra Information
File: C:\Users\DCM Editor Win 10\AppData\Local\VEGAS Pro\14.0\dx_video_grovel_x64.log
File: C:\Users\DCM Editor Win 10\AppData\Local\VEGAS Pro\14.0\svfx_video_grovel_x64.log
File: C:\Users\DCM Editor Win 10\AppData\Local\VEGAS Pro\14.0\ocio_x64.log
File: C:\Users\DCM Editor Win 10\AppData\Local\VEGAS Pro\14.0\dx_grovel_x64.log
File: C:\Users\DCM Editor Win 10\AppData\Local\VEGAS Pro\14.0\gpu_video_x64.log
Problem Description
Application Name: VEGAS Pro
Application Version: Version 14.0 (Build 161) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module:
Fault Address: 0x00000000723D8400
Fault Offset: 0x00000000723D8400
Fault Process Details
Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
Process Version: Version 14.0 (Build 161) 64-bit
Process Description: VEGAS Pro
Process Image Date: 2016-09-13 (Tue Sep 13) 21:47:24
László Kovács
on Sep 21, 2016 at 4:26:22 am
Today I'll try multicam :)
For me there was no crash so far.
(i5 3570, 8GB, win7 home premium 64bit, radeon hd6970)
Best regards
László Kovács
László Kovács
on Sep 21, 2016 at 7:26:11 am
So I took a previous project which was a 2 cam shot. It opened the same as it did in Vegas 10.
I switched to multicam mode, with "show the full frame on external monitor" option.
This project was done originally in Vegas 10 - 1920*1080 25p -the footages are 1920*1080 25p from a Canon XA10,
and 1920*1080 50p from a JVC HM600.
In vegas 13 the multicam preview (half) was about 7-9 fps, in V14 9..12 fps on the same spot.
I made some random edits in V14, scrubbing, etc, did not crash.
Then took an older 4 cam shot, also done in Vegas10. The footages are from Canon XF100 and Sony V1, all 1440*1080 (HDV). The project itself is 1280*720 25p.
V14 was unable to open this project, it just hung (or didn't wait enough...)
V13 opened the same project in a reasonable time. Then saved it as a V13 project.
V14 could open this, but took forever.
A quick, not too accurate comparison:
Originally Vegas 10 opens this project in 5 seconds approximately. Vegas 13 needs 14 seconds to get to the timeline.
Vegas 14 needed 54 seconds! And what's worse: if I save this project in V14 format, it takes 2 and a half minute to get to the timeline.
(Looks like for some reason it reads through the whole .m2t and .mxf files)
There's some room for improvement ;)
Once on the timeline, things go smooth and well.
Best regards
László Kovács
Ron Whitaker
on Sep 21, 2016 at 6:43:27 pm
Oh. Oh.
It appears that it may be best to wait for a few weeks before upgrading. Sounds like there's some crashes out there going on.
Colin Moxey
on Sep 21, 2016 at 11:42:00 am
You will definitely need version 3.00 of Vegasaur to work in MVP 14.
I received an email from Vegasaur yesterday pointing this out and offering upgrades to this new version.
Anything less than version 3 will not work.
Depending on what version of Vegasaur you currently have, you might find that the upgrade price is very reasonable.
Good luck and thank you for your information on MVP 14
László Kovács
on Sep 21, 2016 at 7:44:24 pm
Yes, I know. I got that mail too later that day.
First I want an activated fully functional V14 :))
Best regards
László Kovács
Angelo Mike
on Sep 23, 2016 at 6:40:06 pm
Downloading the pro suite upgrade (my first time using Boris plugins!) because of the $350 deal, along with other upgrades which seem pretty ground. But I've yet to try it. Even if it's buggy, I at least want to buy it at the lower price and keep it while using Vegas 13 until bugs are fixed, but I'm going to try it out this afternoon.
Angelo Mike
on Sep 23, 2016 at 8:59:08 pm
So far, mostly good-I already used Boris FX with success. NewBlue FX, as usual, just makes Vegas crash when I click on the plugin.
