Create Vegas Pro 13 Plugin/Extension
COW Forums : VEGAS Pro
Thomas Ames
on Sep 12, 2016 at 3:07:45 pm
I've recently learned the basics of FFmpeg for trimming down a large file to a smaller file containing certain footage copied from the original file.
I've seen there are plugins/extensions available for FFmpeg in Vegas Pro 13, but they include many options and settings which I don't need (and probably don't understand).
The line I've been using is:
ffmpeg -ss [START TIME] -i [INPUT].mp4 -map 0 -c copy -t [DURATION] [OUTPUT].mp4
I imagine that all I'd need is:
1) GET selected range in Vegas
2) Take start and end time from that selected range
3) calculate duration based on end-start
4) video being selected in range set as [INPUT] file
5) user input for [OUTPUT] file
6) Run that line through a CMD window.
It really wouldn't take long at all and could be done with a simple batch file, but I would like to be able to do it from within Vegas; I just can't find much useful information on creating a plugin/extension nor getting Vegas related syntax.
i.e.: startTime = timeline.selection.start
Could anyone point me in the right direction for learning code for Vegas?
Thanks for your time.
-Tom
John Rofrano
Re: Create Vegas Pro 13 Plugin/Extension
on Sep 12, 2016 at 4:14:31 pm
[Thomas Ames] "Could anyone point me in the right direction for learning code for Vegas?"
You would need access to the Script Development SDK which is no longer downloadable that I can see. I tried to download it from the Sony site but it redirects me to the main page of MAGIX site with no downloadable link in sight. :(
Maybe someone here has an old bookmark that still works. I do not.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Jorma Nippala
on Sep 12, 2016 at 5:58:04 pm
You might try to google "vegas + download development kits".
You should get a cached version of Downloads still.
Jorma Nippala
on Sep 12, 2016 at 6:00:40 pm
Another option there
http://download.sonymediasoftware.com/dev/
(Used to be nice to be able to edit posts here.)
Thomas Ames
on Sep 12, 2016 at 6:12:22 pm
Hey Jorma, thanks for that!
Googling for "vegas pro 13 + download development kits" doesn't yield anything I appear to be able to use.
http://download.sonymediasoftware.com/dev/ looks like I should be able to use it, but I don't entirely understand it.
The second from last option "vegasscriptsdk.zip" looks like the correct choice for me, but would you be able to say if there's a better option, based on what I'm trying to do?
Thank you!
-Tom
Jorma Nippala
on Sep 12, 2016 at 6:28:11 pm
My cached Downloads page gives these explanations
Video Plug-In Development Kit (OFX) updated on Apr. 3, 2013 (409 MB)
Vegas Pro Script Developers Kit - Versions 10-13 updated on Dec. 22, 2010 (135 MB)
JR or others will probably advise further.
John Rofrano
on Sep 12, 2016 at 10:10:23 pm
[Thomas Ames] "The second from last option "vegasscriptsdk.zip" looks like the correct choice for me, but would you be able to say if there's a better option, based on what I'm trying to do?"
That's the one you need. The Script SDK.
~jr
Thomas Ames
on Sep 12, 2016 at 10:44:11 pm
Thanks for that. Any place I can check out the proper Vegas related syntax?
John Rofrano
on Sep 12, 2016 at 10:57:00 pm
[Thomas Ames] "Any place I can check out the proper Vegas related syntax?"
It's all in the ZIP file. What it contains is API documentation.
~jr
