1080p workflow desqueezes 1.33 anamorphic ?
COW Forums : VEGAS Pro
David Galindo
on Sep 11, 2016 at 10:47:35 pm
I having a hard time figuring out the right template to start my workflow.
I recorded my footage from my iPhone using FlimicPro. The iPhone is capturing into a 1080p frame at 24fps 16:9. In addition, I am using a 1.33 anamorphic lens that squeezes more into the frame.
When I load the file into Sony Vegas Pro 13, it loads a frame with 2554x1080 with Aspect Ratio= 1.000 (square). No letterbox or pillars. The preview window displays 2554x1080.
When I use Mediainfo, it says the PAR is 2:35:1 and more below:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=2
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 33s 452ms
Bit rate : 66.4 Mbps
Width : 2 554 pixels
Clean aperture width : 2 554 pixels
Height : 1 080 pixels
Clean aperture height : 1 080 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Variable
Frame rate : 24.000 fps
Minimum frame rate : 23.976 fps
Maximum frame rate : 24.024 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1.003
Stream size : 265 MiB (98%)
Title : Core Media Video
Encoded date : UTC 2016-09-11 12:47:12
Tagged date : UTC 2016-09-11 12:47:46
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Is this correct? Or am I suppose to set the frame back to 1920x1080 ? What pixel aspect ratio will I need to use?
Trying to avoid letterbox and pillars after rendering and let the media players add the black bars automatically.
Graham Bernard
Re: 1080p workflow desqueezes 1.33 anamorphic ?
on Sep 12, 2016 at 12:16:01 am
Sounds intriguing! I don't have any valuable feedback, but would enjoy in seeing at least one Screengrab of your anamorphic output and the optical lens attachment on your iPhone!
* Grazie
John Rofrano
on Sep 12, 2016 at 1:26:25 am
[David Galindo] "I recorded my footage from my iPhone using FlimicPro. The iPhone is capturing into a 1080p frame at 24fps 16:9. In addition, I am using a 1.33 anamorphic lens that squeezes more into the frame.
When I load the file into Sony Vegas Pro 13, it loads a frame with 2554x1080 with Aspect Ratio= 1.000 (square). No letterbox or pillars. The preview window displays 2554x1080."
That doesn't seem possible. Everything is correct but it shouldn't be. The video should be 1920x1080 squeezed. Are you sure that you used 16:9 1080p in FilmicPro and not 2.35:1? There is no way that the footage would have come out correctly like it did unless Filmic Pro or Vegas Pro knew about the anamorphic lens (which they couldn't have). But magically, MediaInfo is reporting the footage correctly having more resolution that it should. 2554x1080 PAR 1.0 is 1920x1080 PAR 1.33.
I too am interested in learning more about this setup.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Wayne Waag
on Sep 12, 2016 at 5:02:10 am
Maybe something like this?
http://www.moondoglabs.com/store/#!/c/8525657/offset=0&sort=normal
wwaag
David Galindo
on Sep 12, 2016 at 2:42:57 pm
Correct, that is the lens I am using along with the 52mm filters, Zhiyun gimbal, and a rode videomicro compact.
I don’t have any footage available online yet but here are samples from other folks using the anamorphic lens.
but just to confirm, If I render out to main concept, the aspect ratio will be 1.33 instead of 1.3333?
John Rofrano
on Sep 12, 2016 at 4:10:27 pm
[David Galindo] "but just to confirm, If I render out to main concept, the aspect ratio will be 1.33 instead of 1.3333?"
I would not use an aspect ratio other than 1.0. Most media players don't handle aspect ratios well. Render it out as 2554x1080 with a square aspect ratio of 1.000. If MainConcept can't handle that width then you have no other choice but to use an aspect ratio of 1.3333 but I would render as square pixels if you can.
~jr
David Galindo
on Sep 13, 2016 at 7:08:20 pm
Thanks, it turns out it was the app automatically desqueezing the footage.
but strangely it was unable to convert to the Cineform GoPro file at this resolution. So I turned off the feature and recaptured in 1080p.
For now I am setting the project properties to 1920x1080 with par 1.33, and set the "Maintain Aspect Ratio" to false in the pan and cropping tool. Would this be the best way to desqueeze in Sony Vegas Pro?
John Rofrano
on Sep 13, 2016 at 11:23:28 pm
[David Galindo] "For now I am setting the project properties to 1920x1080 with par 1.33, and set the "Maintain Aspect Ratio" to false in the pan and cropping tool. Would this be the best way to desqueeze in Sony Vegas Pro?"
No, I would set the project properties to the unsqueezed resolution at PAR 1.0. You don't want to be cropping anything. You want to work in the full resolution.
~jr
