can't dragAVI Files in Sony Vegas
COW Forums : VEGAS Pro
Giorgio Bani
on Sep 11, 2016 at 5:44:54 pm
i can't drag AVI files in Sony Vegas 13 pro, i tried by installing codecs, or quick time, and many other tries. i even tried to reinstall the whole windows cause i thought windows file might be dmged or somthing
i've spent so many hours trying to fix this and still can't solve it, i already had this problem once sometimes ago, but i can't remember how i fixed it.
Any ideas?some one can possibly help?cause i'm over mad sorry for disturb ya guys and thanks in advance!!!
Graham Bernard
Re: can't dragAVI Files in Sony Vegas
on Sep 12, 2016 at 12:04:19 am
[Giorgio Bani] "Any ideas?"
I would need to know more about your AVI. So, download MediaInfo or G-Spot (good for AVIs) and get either to analyse your AVI and report back here with what they say. We need information.
* Grazie
John Rofrano
on Sep 12, 2016 at 12:54:25 am
[Graham Bernard] "...download MediaInfo or G-Spot (good for AVIs) and get either to analyse your AVI and report back here with what they say. We need information."
+1
This is the right way to solve it. G-Spot will not only tell you what codec the file uses but it will also tell you if it's installed. MediaInfo will just tell you what codec the file needs. Then go find that codec and install it. If you are using the 64-bit version of Vegas Pro you will also need the 64-bit version of that codec.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Richard Jones
on Sep 12, 2016 at 8:31:03 am
But beware of buying a codec package such as K Lite as there have been many reports of difficulties when this has been done. Much better to import the specific codec and preferably from the author's own site.
Richard
John Rofrano
on Sep 12, 2016 at 4:17:08 pm
[Richard Jones] "But beware of buying a codec package such as K Lite as there have been many reports of difficulties when this has been done."
Yea, I was going to mention that but it may be too late for the warning. It sounds like lots of codecs have been installed including QuickTime which doesn't have anything to do with Windows AVI files. Let's see what codec the file really needs but the damage may have already been done w.r.t. K-Lite. Let's hope not.
~jr
Francois Blawat
on Sep 12, 2016 at 2:22:40 pm
Giorgio Bani ,
I guess I have to ask if you tried to play the .avi file first on your system without using Vegas? What I mean is, awhile back I had an issue under Windows 7 and I could no longer play .avi files. I ended up having to re-install the IndeoVideo codec v5.11 and then performing this.
1. Install IndeoVideo v5.11 with Custom install options
2. Uncheck the Web Browser box and install software
3. Open a 'command prompt' using a rightclick, select, 'Run as Administrtor'
4. Type: cd C:\Windows\SysWOW64 (32bit users can skip this step) - press enter
5. Type: regsvr32 ir50_32.dll - press enter
I was then able to play .avi's fine. I'm not saying this is your issue but the above recommendations will at least tell you if you have the IndeoVideo codec on your system.
FixitMad
Giorgio Bani
on Sep 12, 2016 at 8:46:21 pm
soz guys, didn't looked at pc today, btw i already tried to import a single codec or so and didn't worked!
also what is the problem about k lite?i used it for years, i never had problems! not even with Vegas, what's so bad with it, if may i can ask?
i will try whatever you guys said! thanks for taking your time for answer, it's really appreciate!:)
John Rofrano
on Sep 12, 2016 at 10:15:10 pm
[Giorgio Bani] "btw i already tried to import a single codec or so and didn't worked!"
What codec was that? Is it the codec that the video needs?
[Giorgio Bani] "also what is the problem about k lite?i used it for years, i never had problems! not even with Vegas, what's so bad with it, if may i can ask?"
It blindly replaces some of the high quality codecs that you paid Sony for with free alternatives that might not be as good. We have seen people have render problems with certain codecs and then uninstall K-Lite and re-install Vegas Pro and the problem goes away. This has happened several times so it all points to K-Lite being the problem.
~jr
Richard Jones
on Sep 13, 2016 at 10:22:40 am
"It blindly replaces some of the high quality codecs that you paid Sony for with free alternatives that might not be as good. We have seen people have render problems with certain codecs and then uninstall K-Lite and re-install Vegas Pro and the problem goes away. This has happened several times so it all points to K-Lite being the problem."
A significant number of people on different forums have reported problems. sometimes quite seriou and not always confined to Vegas, after installing the K Lite package. I've seen very few favourable reactions to the package. The general and very sound advice is to avoid it at all costs.
Richard
Francois Blawat
on Sep 16, 2016 at 8:32:52 pm
[Giorgio Bani]
Did you ever get this issue resolved? Just curious as to what the resolution was/is.
Thanks.
FixitMad
Giorgio Bani
on Sep 17, 2016 at 3:42:26 pm
Hello, i didn't had time these days, but today i formatted once again, and decided to try to deal withouth any pack, in the end i listen to the guys abose, tried with media info, and it said it was a fraps file, even if actually i didn't used fraps to record it, but another program, still i already had fraps on the second HD, but well i tried to uninstall/reinstall and looks like it actually works now, oh my god i feel so damn stupid that i wasted so much time for this thing, and in the end it was just like....
Anyway thank you all for the media info tip, and for take your time to answer in my post, sorry for the late reply, and thanks again! <3
-Gio
Graham Bernard
on Sep 17, 2016 at 3:47:50 pm
You're welcome!
And thanks for getting back with your "way out".
* Grazie
John Rofrano
on Sep 18, 2016 at 12:57:06 pm
I'm glad you figured it out. You could have installed 1000 codec paks and none of them would have had Fraps. This is why you need to understand the exact codec that the file needs and only install that codec. At least now you know the procedure for next time.
~jr
