Your freind till the end! Once again! Need more advice guys!
COW Forums : VEGAS Pro
Adam Harrington
on Sep 11, 2016 at 7:28:10 am
The ending credits were taken from a text file my gf made. Yes, she typed by hand.
Now you see alignment issue?
Where do I fix this?
:D
TY as always you guys are lifesavers.
Graham Bernard
Re: Your freind till the end! Once again! Need more advice guys!
on Sep 11, 2016 at 7:59:26 am
[Adam Harrington] "Now you see alignment issue?"
Yes. It's sometime since I've used this Feature, however you're trying to align inside a single column, and here that column is a HEADING template. You need to use, for your purposes a 2 column template. Then you can get busy with Left <> Right alignment.
* Grazie
Adam Harrington
on Sep 11, 2016 at 8:41:56 am
airplane over head , huh? I'm not very good at learning stuff the first try LOL, ask someof the other folks.
Run that by me again? :D
Graham Bernard
on Sep 11, 2016 at 9:09:50 am
* Grazie
Adam Harrington
on Sep 11, 2016 at 9:14:45 am
Thanks I appreciate this, but. You are preaching to the converted. :D
I don't know why some of them, are shifted all over the place. Is it my wife's notation's?
Graham Bernard
on Sep 11, 2016 at 9:56:37 am
[Adam Harrington] "I don't know why some of them, are shifted all over the place. Is it my wife's notation's?"
Yes.
* Grazie
Steve Rhoden
on Sep 11, 2016 at 9:14:16 am
Or just type it up in photoshop, then simply drop it in Vegas, and keyframe it from top to bottom...
That any easier to understand?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Adam Harrington
on Sep 11, 2016 at 10:26:32 am
She used wordpad as she watched them, if we started over, what would be the best idea. Photoshop for text seems odd, but you guys know better than I do
Graham Bernard
on Sep 11, 2016 at 10:59:27 am
[Adam Harrington] "if we started over, what would be the best idea. "
Only time will, only time will tell....
* Grazie
Adam Harrington
on Sep 11, 2016 at 11:25:58 am
I love you guys. ;)
László Kovács
on Sep 11, 2016 at 1:15:57 pm
Hi, once I mentioned somewhere, but can't remember...
So, use a text editor which can save to pdf. If you don't have such, look for freeoffice.com :)
That way you have the conbenient way to input text.
Then you can easyly import the pdf to photoshop, and so have it converted to graphics.
Then the rest is intuitive :)
Best regards
László Kovács
John Rofrano
on Sep 11, 2016 at 7:32:10 pm
Actually all he needs to do is what Graham has already suggested but he didn't understand. Change the row type from Header to 2 Column and you're done. No need for any other tools. Adam was using the header type to make two column text which is impossible to line up. Use the appropriate row type and everything will line up as expected. It was clearly shown in the video that Graham linked. You can even paste from a WordPad document. Just use a TAB between the columns and Vegas Pro will line them up for you.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Adam Harrington
on Sep 11, 2016 at 10:45:27 pm
Ok, let me slowly work that in.
TY again guys.
