Animate Pinch/Punch Video FX
COW Forums : VEGAS Pro
Thomas Ames
on Aug 20, 2016 at 6:11:43 pm
I'm using Vegas Pro 13 and trying to use the Pinch/Punch Video FX.
I'm using Medium Punch as my maximum "pulse", which is at "Amount: 0.500"
To try to ease into the 0.500 value, I have the four frames before the max set at 0.100, 0.200, 0.300, 0.400. Then, I let the max pulse hold for 6 frames before backing off in reverse order.
It looks better than the 0 to 0.500 did, but it still looks a little rough.
Here are images showing my timeline and some Effect Windows: http://imgur.com/a/pc4Fs
Is there a way I can have Vegas automatically animate that effect to make it smoother?
László Kovács
Re: Animate Pinch/Punch Video FX
on Aug 20, 2016 at 6:27:27 pm
Did you try to right click a keyframe and set it to "smooth"?
Thomas Ames
on Aug 20, 2016 at 6:47:02 pm
I'm not exactly sure what you mean by selecting a keyframe.
I see that I can set keyframes in the Pan/Crop tab of the Video Event FX window, but I only see that applying to a "zoom" effect.
I'm also not sure what you mean by "set it to 'smooth'". Could you elaborate?
Thank you!
László Kovács
on Aug 20, 2016 at 6:49:21 pm
Sure, later. Right now I'm far away from my computer, I'll try to help better when I get back ;)
László Kovács
on Aug 20, 2016 at 8:46:56 pm
So here I am ;)
Apply Punch FX to your clip (event).
Then when you open FX properties, click on the animate button on bottom left:
Then you'll see a timeline, here you can add/remove/move/modify keyframes.
When you right-click a keyfram, you can change the interpolation method between them.
I guess you are looking for the "smooth", but you can try the others too.
By default the interpolation is linear.
I hope I could help
Kind regards
László Kovács
on Aug 20, 2016 at 8:59:11 pm
Oh, I forgot to mention, that instead of an event, you can apply the FX to the track itself.
Animating works similar in this case...
Thomas Ames
on Aug 20, 2016 at 9:49:02 pm
Thank you very much!
I missed that "Animate" button.
